Today while going to school I noticed something was squeaking when the car was in motion. Sounded like metal against metal sound. Oh no! i thought, not another trouble! damn, i must have a lemon car, or it was abused by previous owners!
I need to replace the front axle because clicking noise when turning, and yesterday I floored it while turning, making loud clicking like always, then today it would sqeak when going forward.
Did that cause it, or something else?
I'm worried about the wheels fall off, is that possible? or something might make fire, if metal contact somewhere.
Talk about timing! Next week is Finals, something more I have to worry about.
Wheel bearing is the bearing inside the hub. They dont really wear out fast at all, but if you have oversize rims with a wrong offset you'd put more pressure on them and that could cause for them to fail.
a wheel bearing job is an expensive one....say $325 for the bearing itself. the job is easy, but fuckin' costly.
for futur reference, to chekc thats its your axel/cv joint, you take off the wheel and grab the axel near the cv joint/boot. if you can move it up and down...therfore if it has a lot of lateral play, then that baby is fucked...like on mine.
brake job...you can do that yourself. take the wheel off and rub your index finger slightly down the surface of the rotor. if you feel any grooves, dips valleys or peaks, then your rotor is wearing un-evenly. you can also check by looking at the rotor head on and rotating it with your focus on the thickness of the rotor. if it waivers at any point, again, un-even wear. in that case, you should get the rotors machined providing theres enough surface to warrant that. too little, and you'll need new rotors. if your pads are really un-even, then replace them likewise.
this is caused becasue the brake pads were installed in-correctly or the caliper is siezing therefore when depressed, it stays depressed causing the pad to wear excessively ont he rotor. it could also mean your rotor is warped which can happen from anything....baning the wheel, over torquing the lug nuts, un-evenly torquing the nuts, or faulty calipers.
should only take a half day providing you have the absic tools and a manual on hand.
Pads $25 and rotors $30 at this parts shop on Painted Post and Markham road.......... it's the parts store with the steet light in the window
product quality is pritty good..... only one brake caliper on my 92 is workin so i change my brake pads on that wheel about once every 2 months until i can afford 4 rebuilt calipers
Thats gonna be ALOT more expensive than you think. Because now that youre using only one brake, that disk will wear out more than the otherone, so when you fix your calipers you're going to have assymmetrical braking power (meaning the unused disk will bite more than the used one). This condition is VERY dangerous as it might make your car spin when you press the brakes. Ok so you're gonna need to overhaul all the calipers, plus you're gonna need the left and right disk for the axle that works, which I'm guessing is the fronts. Since you cant replace the disk on one side only. Kinda like shock absorbers. you cant only replace the left or right, its both or nothing...
i've got 4 new rotors in boxes waiting for the when i get enough dollars to overhaul the calipers...........i'm not to worried but thankx 4 the advice though
