auto tranny fluid change on a 92 sedan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2006, 10:54 PM   #1 (permalink)
View jjminch's Photo Gallery
AE92 auto tranny fluid change on a 92 sedan
Hey guys, my car only has 80k miles on it. It vibrates horribly when stopped, and in Drive. I think I need to change out my fluid. I can prolly find the drain plug, but where do you fill it up at? Is it on the side of the tranny, do I need a pump? Any additives I should add in there to help smooth things out? What type of fluid should I throw in there?
Josh
1991 Toyota Corolla DX Sedan-Beater w/ broken a/c
2004 Yamaha R1- 10 sec daily driver
jjminch is offline   Reply With Quote
Old 01-05-2006, 11:10 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The drain for the tranmission is the square pan next to the engine oil drain pan. You'll need a 10 mm hex key (not socket) to remove the drain plug.
To refill, pour the fluid into the diptick tube. You just need a funnel.
I suspect the problem is that you need new motor mounts, not a problem with the transmission fluid.
2007 Camry 2.4L 5M
Old 01-06-2006, 12:51 AM   #3 (permalink)
I thought it could be the mounts too. I should have posted it. But one case against it is: the car vibrates while in D stoppped. When I put it in N almost all goes away. Mounts are a PITA to do, hopefully its not that.
Josh
Old 01-06-2006, 03:59 AM   #4 (permalink)
setiing up the email notice
Josh
Best Auto tranny fluid on a 87? Falling Rock Pre-88 Toyota Pickup/Hilux 1 12-06-2005 06:13 PM
How do i change my tranny fluid? JeremyL Archived Corolla threads 10 08-08-2005 01:45 PM
tranny fluid change skoman Camry & Solara Lounge 3 05-09-2002 08:59 AM
How often should you change your tranny fluid? poorguy Camry & Solara Lounge 2 04-01-2002 03:00 PM
