I looked again, in the fusebox area, for the diode, that connects to the idle solenoid. I know what a regual diode looks like, but am not sure what this 'Toyota Diode' looks like. I looke dall over the Internet and cannot find a description of the location where it is, and what it looks like. I have the schematic, but that does not show where in the area of the fusebox it is, or what it looks like.
I could not get the big plastic fusebox out. I think I can just remove the bolt fromt he bottom, and pull the plasitic piece out. But, I am really arafid of screwing something up, pulling some wires... as there is absolutely no room at all to do antyhing! and if I had a good description, procedure, and location of the diode, I would not have to go on this search. Toyota, like al car manufacturers purposely make it impossible to work on. They expect you to drive til it breaks and send it to the landfill! They made it impossible to fix!
Can anyone point out a location of a picture, a description of the exact location and shape of Toyota's Diode?
Like I siad I have the schematic, but all I end up doing is chasing the wires into an area where they disappear into a rats nest, behind big plastic junction boxes.
Is it behind the fusebox? I do not see a regualr PCB anywhere, so I suspect the diode must be in some module in that area, maybe with some generic marking. Or maybe it will have diode printed on some type of module?
Only other choice is to find a wrecking yard witht he same model car in pieces and hoefully access to a fusebox out in the open, already ripped out of the car..
update:
shematic show the circuits for some of these parts are in the wiring in the passenger compartment on the passenger side, so maybe the diode(s) are located there?
http://opc.mr2oc.com/online_parts_ca...CorollaFWD.pdf
Idle-up (7 - D -26 )
Note: My A/C idle-up works just fine.
again, it's the idle-up for the headlights that is not coming on. It worked since the car was new It stopped working a couple of weeks ago.
