The MOST important thing that will help you take those corners better is a set of good tires. That should be your first mod if you plan on maintaining that stock setup. After, get a set of swaybars (which will help reduce body roll). If that doesn't satisfy you, you'll need to get lowering spring and stiffer shock (preferably adjustable). By then, your parents might be angry with the amount of modification you've done to thier car so you might as well go for a full weight reduction and chassis bracing. When in doubt, go in the order I listed above.
1. Tires & Wheels
2. Swaybars
3. Spring & Shocks/Struts
4. Weight Reduction (help with the 40-70mph)
5. Chassis (strut bars and underbraces)
If you actually follow through with any of these modifications, do them one at a time and spend a lot of time identifying how they have changed the handling dynamic of the car.
The hippies of today will be the squares of tomorrow.
