Small problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2006, 11:33 PM   #1 (permalink)
View White89SR5's Photo Gallery
Small problem?
Well my problem goes like this. Anytme I make a hard U-turn my engines dies until the car straightens out. My thinking is that this happens because the car is Carb'd so the fuel may be splashing around and not making it to it's intended destination plus the intake manifold may have alot of crap built-up from all of he miles which maybe causing a problem as well. If it is the carb what can I due to stop this, besides stop making U-turns which is not really a possiblity because for some resean there seem to be a lot of places I go where I have to make a U-turn. If it is the intake manifold I thought about running and induction system cleaner from work, but I am scared the it will knock something loose not only in the intake manifold but also around the piston rings because I am sure there is a ton of stuff around those keeping them sealed since the car has 242,820 miles on it without a rebuild, so to get around that I am just going to pull a manifold from the junk yard clean it out and maybe try to port match while I am in there and see if that helps. If anyone has any other suggetions or comments it would be great to hear them!! Thanks in advance!!
Hear no evil...Speak no eveil...If you don't bring that s**t around you...You ain't got nothing to worry about!!
http://WWW.MORECASHFLOWNOW.COM
Extra Cash Is Always Good!! Click the link to see how to get it!!
White89SR5 is offline   Reply With Quote
Old 01-14-2006, 12:38 AM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Does this only happen when you have a half tank of gas or less? Cause my bud has the exact same problem with his 95 grand prix......He has a spilt his line going up to the fuel pump in his tank from the bottom filter/intake, just a thought...We plan to replace it when it gets warmer...Radd Guy...
Raddman is offline   Reply With Quote
Old 01-14-2006, 01:33 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I'm pretty sure thats not why it's doing it! I have the carbed sr5, 89 also. I drive the shit out of it, slidin throug corners and such. Only time it stalls is when I forget to push the clutch in when I screw up. I can turn the wheel fully left and right, the rpm drops but it doesn't stall. What rpm does your car idle at?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 01-14-2006, 01:55 AM   #4 (permalink)
No it happened the other day an di had a full tank! I can turn the wheel lock to lock too!! I am talking about when the car is in motion during a U-turn!!
Old 01-14-2006, 04:31 AM   #5 (permalink)
View karugs's Photo Gallery
But if you straighten it out the car is still in motion so the fuel would still be pushed backwards. Why not check the more direct connections first, P/S pump, belt and such?
karugs is offline   Reply With Quote
Old 01-14-2006, 07:23 AM   #6 (permalink)
When I turn the wheel the rpms increase so I don't think that is what is causing it to stall. when I said straighten out I meant when the car comes out of the U-turn and the car levels out.
Old 01-14-2006, 07:28 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Carbs dont have problems with fuel sloshing in the fuel tank, because carbs have the float bowl, which in essence is an auxiliary surge tank.
I'd say the problem has something to do with the needlevalve and floats.
Old 01-14-2006, 08:01 AM   #8 (permalink)
Can the needlevalve and floats be adjusted on this carb and if so how?
Old 01-14-2006, 12:36 PM   #9 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Unless the needle and float are way out of adjustment there should no no reason to adjust. But adjustment is easy.
First buy a manual for your car/engine type or get one from a library and read up on it.
Second buy a new needle and seat, if you are going to take the carb off and remove the floatbowl you may as well replace these anyway.
Then you have to remove tha carb, flip it upsidedown and remove the bottom half of the floatbowl. Remove the float pin take the floats out and replace the needle and seat. Put the floats back in and make sure the pivot pin is secure. Then you just measure the float height and bent the tab to adjust it to spec. by measuring from the top of the carb float bowl to either a line on the floats to the top of them, carb still upsidown, replace the float bowl and reinstall the carb.
Of couse all of the foregoing is to be ignored if your manual says otherwise ;o
I had a freind who used to have and earlier model Tercel who had the same problem but on his car it only happened when he was making a hard left in autocross, never happened under normal driving.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
small problem with side wall of passenger side rear tyre Aussie Ed Camry & Solara Lounge 7 11-15-2005 02:25 AM
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 04:02 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
99' Camry Start then dies Problem EBMCS03 Camry & Solara Lounge 6 08-30-2004 09:57 AM
Motor Mount problem and other, please help lazycat Camry & Solara Lounge 4 08-16-2004 09:32 PM
