91 ignition problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2006, 11:18 PM   #1 (permalink)
View jrs87's Photo Gallery
91 ignition problem
sometimes when i try to start it, i turn the key but nothing happens. it doesn't turn over, but all the lights dim when the key is turned. starter doesn't click or anything either
but if i turn the key to the on and off positions a few times and then try it, it will start
is there some sort of sensor or something that would cause this?
jrs87 is offline   Reply With Quote
Old 01-18-2006, 09:54 AM   #2 (permalink)
View tashirosgt's Photo Gallery
This is a typical symptom of a starter that's gone bad. As to whether a sensor could cause it, I don't know of any sensor in the 91that could. My guess is that your starter is bad or perhaps your ignition switch is intermittent.
tashirosgt is offline   Reply With Quote
Old 01-18-2006, 12:34 PM   #3 (permalink)
View White89SR5's Photo Gallery
I had that happen to me recently and it turned out to be the starter contacts.
Hear no evil...Speak no eveil...If you don't bring that s**t around you...You ain't got nothing to worry about!!
http://WWW.MORECASHFLOWNOW.COM
Extra Cash Is Always Good!! Click the link to see how to get it!!
White89SR5 is offline   Reply With Quote
Old 01-18-2006, 12:50 PM   #4 (permalink)
I Break Everything!
Froggmann's Avatar
View Froggmann's Photo Gallery
Like White89SR5 said look at your contact wires. Make sure they are free of corosion on both the battery and the starter. If that doesn't help tehn likely either the starter or solenoid is getting stuck either way a replacement starter assembly is in order.
1993 OJ Bronco 250,000 miles Back on the road, fun truck.
2002 Nissan Maxima, keeps me nice and spoiled.
2001 Highlander Limited, for the wife.
Froggmann is offline   Reply With Quote
Old 01-18-2006, 04:50 PM   #5 (permalink)
today while fooling around with it i found out that if it doesnt start in park, i can put it in neutral and it will start
91 previa transmission problem grego Previa Forum 6 05-20-2011 02:42 PM
1985 pickup w/22r ignition problem travisdecpn Pre-88 Toyota Pickup/Hilux 7 03-22-2006 12:10 AM
91 4runner -"electronic control unit " or " electronic ignition Bobbie 4Runner Lounge 1 11-05-2005 02:33 AM
Ignition problem woody Camry & Solara Lounge 2 11-19-2004 02:36 PM
starter problem 91 pickup 91toyindiana 89-95 Toyota Pickup/Hilux 5 11-05-2004 03:12 AM
