alltrac corolla wagon timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2006, 02:29 PM   #1 (permalink)
View alltrac corolla's Photo Gallery
Hi,
I've got a corolla alltrac wagon with a 4afe motor in it. I got it with a rebuilt head but then it blew a head gasket so I got it for cheap. We replaced the head gasket but now can not get it to start. The motor will not start now, though it did before we took it apart. i'm thinking we got the timing wrong when we took the head off, as you know you have to take the cams out so maybe we messed up the timing. It turns over, we're getting spark and there's compression, so I am at a loss as to what is going on and so I think it must be timing. ANy quick ways to check the timing? Can I take the distributor out and re-install it with piston 1 at TDC to remedy the timing problem? Also how are the cams or where are the marks to re-align the cams when they are re-installed? I'm thinking we messed it up somewhere? ANy ideas? THanks for your help!
alltrac corolla is offline   Reply With Quote
Old 05-14-2006, 11:10 AM   #2 (permalink)
View No_Bs's Photo Gallery
Wow, I'm having the exact same problem with my 4afe, hopefully someone can help us out.
No_Bs is offline   Reply With Quote
Old 05-14-2006, 02:07 PM   #3 (permalink)
The cams have installation marks on them, the exhaust is under a tooth and the intake is under a pit, align the pit with the tooth and roll the cam down into place with the gears meshed. I did this and still something is not right. My distributor only goes in one way, so no I don't believe that would do anything, expecially if your cams are misaligned.
Does an 2005 Corolla have a timing belt or timing chain? Teutonic Speedr Archived Corolla threads 5 09-03-2005 04:41 PM
Does 2000 Corolla Ve has a timing belt? John2000ve Archived Corolla threads 5 02-03-2005 12:44 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
My 1977 Corolla Wagon vintagecorolla Archived Corolla threads 3 03-23-2004 08:17 PM
4A-FE to 7A-FE - 90 corolla dx wagon Heyman-FX16GTS Hardcore Tech and Competition 0 07-26-2003 11:53 PM
