Anyone know how much a set of locks for my car will cost since I don't want to replace just 1 and have 2 different keys. My drivers side tumbler is all siezed up and I need a handle anyways since it's cracked on the inside. But yea the passenger one is worse won't take the key in. I just took the driver side one apart and it's all full of salt and some rust so the key isn't doing anything...
I had to replace locks on a chevy that i had a few years ago and all i did was take the locks to a locksmith with the spare key and they made the locks fit the key. But to answer your question, unfortunately i have no idea how much they will cost you.
It comes in aerosols now, I had the same troubles in my supra and it worked wonders.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
I don't need a lock smith. I have the rumber out. It's just so jammed up with salt and is starting to rust I was just thinking of replacing all the tumblers in the car. besides I busted the little thing at the end because toyota thought it was cool to make the handle impossible to get through the hole with the little lock arm out and since I couldn't turn it...
don't think he would still have it, I need a few parts anyways so I want to buy that gts in the fs forum, plus thats the full 4age conversion I will need
Take it out and have a locksmith clean it. Then once it's clean apply graphite on it, NOT WD40. That's a common problem with brass keys. WD40 is fine as it displaces water (if it's frozen) but as soon as you can, apply the graphite.
I had exactly the same problems (fussy drivers-side lock, passengers-side seized completely) plus a seized trunk lock mechanism. Go to a good scrap yard (where they let you do the work yourself and charge minimal prices) and pay a locksmith the measly $17 per cylinder to have them re-keyed.
After they're in, keep using the lock de-icer/lubricant. Even in the summer, because water gets in. Use it about once a month (just a quick spray will do) and you'll never have problems again--unless the actuating rods seize too (like mine did)
__________________ 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
I worked for a dealer in Chicago, and had supplies to rekey lock cylinders, and cleaning the cylinders for the customer was a way to help them save money from buying a new one, and basicly it will be as good as new.
I pulled it all apart myself, have done it with the jetta but it was different. Cleaned it all but a couple springs for the slides are missing. I might see if toyota will sell me just the cylinder and I can redo it myself
