Raspy noice when accelerating... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2006, 01:23 PM   #1 (permalink)
LV2001_Corolla
View lasassy2412's Photo Gallery
USA Raspy noice when accelerating...
Does anyone know what can cause a raspy noise when accelerating? I have a 2001 Corolla and it only makes the noise when I press the gas. It does not do it all the time. I thought it was the spark plugs but I changed them and it was not that. I got a better air filiter and that was not the problem. Maybe my fuel injectors?? please help... Thanks
lasassy2412 is offline   Reply With Quote
Old 01-19-2006, 06:01 PM   #2 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
If you ask me its just throttle opening, when I press the gass or just open up the throttle theres a loud surge sound through the intake I wouldnt discribe it as raspy but it depends, does it get louder when you open up fully?.
canadianae92 is offline   Reply With Quote
Old 01-19-2006, 06:39 PM   #3 (permalink)
View polo708's Photo Gallery
raspy? Sounds like an exhaust leak to me, but if you havent touched the exhaust lately then thats probably not it. Could be knock (detonation)... do you know what knock sounds like? Its almost like tons of marbles bouncing around in your engine...
2004 Supercharged Corolla S
polo708 is offline   Reply With Quote
Old 01-19-2006, 08:41 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
loose heat shield on the cat or on the underside of the car?
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 01-19-2006, 11:08 PM   #5 (permalink)
Mr. Nice Guy
Where is the raspy sound coming from its hard to tell you wha tit is unless your more specific.
Old 01-20-2006, 12:49 AM   #6 (permalink)
LV2001_Corolla
USA
Sorry.. Let me describe it better. It is more of a hissing noise. It is coming from the engine. It sounds almost like when you have a hair spray can that is almost empty and the last little bit is trying to spray out. It does not make the noise when I am in park and I hit the gas, only when I am driving.
Old 01-20-2006, 02:15 AM   #7 (permalink)
Mr. Nice Guy
Well that doesn't help me to much I've never used hairspray, but I think it might just be the intake whine, mine for example hisses once in a while I don't think anything is seriously wrong with the ENGINE, but open you hood with the car on and pull on the throttle to rev it and try and locate the sound as best you can.
I use an axe body spray and im just imagining the sound as that spraying?
Don't worry to much about it if it was something serious in the engine you'd notice it running rough sound weird or acting weird probably, just you know check the oil if you haven't yet.
Old 01-21-2006, 02:14 PM   #8 (permalink)
LV2001_Corolla
Thanks for all comments.. And I had the oil changed a couple of weeks ago.
Old 01-21-2006, 11:49 PM   #9 (permalink)
Mr. Nice Guy
Also check the compression to be safe.
Old 03-10-2006, 04:06 AM   #10 (permalink)
View Turk_Rolla's Photo Gallery
heres my dilema...so a week ago a clump of ICE fell off a truck and hit underneath my 98 LE corolla. It was a loud buzzing and humming sound when in idel and accelarating, now just a couple of hours ago i dunno what happened but the noise (while i was driving) just got 10X worse, now it sounds like a muscle car but louder the more i hit the accelarator the louder it is. when i let go, no sound. a couple of my friends says it could be a hole in the manifold, or exhaust pipe, any ideas? and how much do you think it'll cost? the sound sounds like its comming near the back of the engine closer to the "cockpit" of the car more then the bottom or front of the car. is it possible to patch up a hole if there is one?
Turk_Rolla is offline   Reply With Quote
Old 03-10-2006, 06:38 PM   #11 (permalink)
maybe the ice damaged the air box down in the outer fender, this could cause a loud noise like your describing,
Check in the drivers front fenderwell in front of the tire for any damage
Old 03-18-2006, 07:26 PM   #12 (permalink)
i got it welded, it was actually the front exhaust pipe connecting from the manifold to the catalytic converter. when i just put a new exhaust pipe on it, started makeing the sound again. can welding break apart, cuz i know it can crack. but how long can the crack last until the welded pipe breaks apart? can it even break apart?
Old 03-18-2006, 10:17 PM   #13 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
If it breaks again, its probably because there is no flex pipe or flex flange in between. The fukcers that did my exhaust a long time ago on one of my Civics did that to me, quoted me for the exhaust, got it done, about a month down the road it breaks.. I'm like so I go back and dude tells me.. Oh you don't have a flex pipe! I say.. wasn't that part of the price?? he says.. no, you have to specify if you want one, its $75 extra. WTF!
Vibration when accelerating psyjoniz Camry & Solara Lounge 2 12-26-2005 12:42 AM
Stuttering when accelerating richgarcia87 1st Generation (1995.5–2004) 1 12-06-2005 06:34 PM
vibration when accelerating on a turn onomatos Archived Corolla threads 2 11-30-2005 10:19 PM
Vibration while accelerating Othello Camry & Solara Lounge 14 09-03-2004 10:45 PM
Hesitation when accelerating? dx-r Archived Corolla threads 6 04-26-2004 12:35 PM
