Mysterious oil leak + wierd sound.. see pictures - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2006, 05:14 PM   #1 (permalink)
TN member
View Mins's Photo Gallery
Hi people,
I was wondering if anyone could help me out with this.
I own a 2005 corolla automatic with 4400 miles on it. Today I was looking underneath my car and noticed a trace of oil leak near my passenger side CV joint. It is definately not a brake fluid, since brake line is nowhere near the CV joint. I've included some pictures.
This is driver's side CV joint, which looks fine.
This is the passenger side CV joint. Some sort of leak is visible.
Another view of the leak.
What could be causing such leak? It shouldnt be water since it hasnt rained here for days. I also notice a slight, but clearly audible squeaking sound at passenger side front wheels, which is the place where the leak is. It sounds as if the brake pads are touching the rotor.
Any input will be greatly helpful. Thanks!
'05 Corolla LE Silver Streak Mica
Mins is offline   Reply With Quote
Old 01-19-2006, 05:50 PM   #2 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
I beleive that would be a transmission fluid leak, you have to replace the seals or what ever you called it, my tranny was leaking fluid and i had the same thing only the whole area was wet and I replaced the seal and its good so far.
edit: never mind i just noticed its on the brake side, its probably brake fluid not much else can get their.
canadianae92 is offline   Reply With Quote
Old 01-19-2006, 06:55 PM   #3 (permalink)
20v 4dr AE92
View Corolla101's Photo Gallery
doesn't look like much of a leak at all, wash off the area and check back in a week to see if it really is a leak
Corolla101 is offline   Reply With Quote
Old 01-19-2006, 07:11 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
maybe one of the sealed wheel bearings in the hub is leaking grease?? kinda a long shot but i can't think of anything else
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 01-20-2006, 05:03 PM   #5 (permalink)
I Break Everything!
Froggmann's Avatar
View Froggmann's Photo Gallery
You know if it has that many miles and something is squeaking then I would just take it in under warranty. Have them inspect the bearing in case it is bad and overheating also have the brakes checked to see if the caliper is sticking.
1993 OJ Bronco 250,000 miles Back on the road, fun truck.
2002 Nissan Maxima, keeps me nice and spoiled.
2001 Highlander Limited, for the wife.
Froggmann is offline   Reply With Quote
Old 01-21-2006, 12:05 AM   #6 (permalink)
View CorollaULEV's Photo Gallery
On a car with only 4400 miles on it, I wouldn't worry much about something that small. My guess....it very well may be a small leak from the CV joint OR the wheel bearing. However, I'd rather think that is simply related to the break-in period. Toyota might have packed a little too much grease inside the wheel bearing or (more likely) the CV joint - and it's gotta have somewhere to go. Just watch and see what happens.
Trav
CorollaULEV is offline   Reply With Quote
Persistent mysterious oil leak 89 pixelpadre Celica Forum 15 04-21-2005 10:01 AM
oil leak driving me crazy please help jpsamson27 MR2 Forum 4 04-10-2005 05:36 PM
Massive Oil Leak..possibly front main seal EMMETT03 Camry & Solara Lounge 4 12-06-2004 09:46 PM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
help! oil leak 97Camry/blue Camry & Solara Lounge 7 07-26-2004 09:53 PM
