94 gauge cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2006, 10:34 PM   #1 (permalink)
View MrCool2571's Photo Gallery
Japan 94 gauge cluster
hey folks i was on ebay when i saw this http://cgi.ebay.com/ebaymotors/93-94...31046305QQrdZ1 its says 95 corolla gauge cluster with tach. i was wondering if it fits my car which is a 94 with no tach. and he says there is no plastic will my old gauge plastic fit? thanks in advance
MrCool2571 is offline   Reply With Quote
Old 01-20-2006, 11:48 PM   #2 (permalink)
View rfragachan's Photo Gallery
Thumbs up
I changed my cluster not long ago on a 96 corolla. If the shape is the same you should have no problem at all and the plastic should work. It is usually plug and play. In my case since my corolla used to be very basic I had to run a wire to the distribuitor on the hood and plug it in order for the tach to work. However this is not usually the case. I bought my cluster at a junk yard and it was only about 50 bucks with 50k on it
Good luck
Let me know how it goes.
rfragachan is offline   Reply With Quote
Old 01-21-2006, 12:45 AM   #3 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Yeah I swapped too. Plastic should fit. Speedometer assemblies will not swap between the two... so you wont have the right mileage on the odometer.
For me it was plug and play, just hooked all the wires up the same as to the non-tach cluster.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 01-21-2006, 11:45 PM   #4 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $120200
View Piloter's Photo Gallery
Just did the tach swap as well on my '96, the only thing that's been a problem so far is that the fuel gauge is completely off. The light'll come on when it's honestly close to empty, but other than that the E on the gauge corresponds to about half-full or a third full for 'real' fuel level.
Piloter is offline   Reply With Quote
Old 02-21-2006, 01:09 PM   #5 (permalink)
View Sven's Photo Gallery
Hey guys,
I wanted to get some more replies from this as I'd like to do the same thing as rfragachan.
How many of the 94's are plug and play with the tach-dash? Is there an easy way to find out without ripping the dashboard apart?
It definitely looks better with a tach!
edit: It seems like Ukrainian102 had luck with it here: '95, Looking for Tachometer
I just wanna see if it's the same for the '94s. Mine's the "Special" so could anyone tell me if this is one of the models that was designed to accept a tach? Thanks.
Sven is offline   Reply With Quote
Old 02-24-2006, 01:32 PM   #6 (permalink)
Question
Can anyone help me out?
I'm hoping I don't need to spend hours taking the dash off just to find out I need to get a lead coming off the block or at the fuse panel at the least.
Old 02-24-2006, 03:29 PM   #7 (permalink)
You asked for it...
View azcorolla's Photo Gallery
I'm reluctant to convince you to do anyting based on just my word, but I did this conversion, too, and it was a simple plug and play. Getting the old one out was very easy, and the new one popped right in. Even the fuel guage works fine. Anyone want to buy a non-tach cluster? That thing is boring!
azcorolla is offline   Reply With Quote
Old 02-24-2006, 04:03 PM   #8 (permalink)
Is yours a '94 also? So far I've seen good plug and play with a '95... hoping there's no difference.
Gen. 2 V6 gauge cluster question xavior66 Camry & Solara Lounge 10 08-09-2003 06:38 PM
