Removing Head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2006, 03:21 PM   #1 (permalink)
View mnrolla's Photo Gallery
Removing Head
I'm working on replacing the head gasket on my son's 98 Corolla (man you have to take darn near everything off or out of the engine compartment to remove the head!) Does anyone know if the head will come off without unbolting the exhaust manifold from the exhaust system? Yea I do know it has to be unbolted from the head but I was wondering if the head would come off with the exhaust manifold still in the engine bay.
Thanks!
Bill
mnrolla is offline   Reply With Quote
Old 01-21-2006, 05:41 PM   #2 (permalink)
View deekay140's Photo Gallery
you have to remove the o2 sensor, in order to unbolt the pipe from the manifold. there is also 1 14mm bolt from the exhaust manifold to a bracket on the block. its a few inches from the pipe bolts and the head on the bolt faces the passenger side of car.
Did you remove the timing cover? if not, there is a 10mm bolt that goes through the timing chain guide into the cylinder head.
that is an interference motor, so be careful on your timing.
deekay140 is offline   Reply With Quote
Old 01-22-2006, 07:25 PM   #3 (permalink)
What do you mean by "an interference motor"?
I'm still working on getting the timing cover off. Trying to work on this as job & other "duties" around the house allow.
Good to know to take the O2 sensor off first. I'm trying to avoid pulling the exhaust manifold if possible. One less thing to remove if possible.
Bill
Old 01-22-2006, 09:34 PM   #4 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Interference motor: If the timing is off, there is the possibility that the valves will hit the pistons.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 01-22-2006, 09:37 PM   #5 (permalink)
leave the exhaust manifold on the head, no reason to remove it.
Old 01-23-2006, 09:15 PM   #6 (permalink)
That's kinda what I suspected an interference motor was. Definitely no fun getting valve timing off. A buddy did that once on his motorcycle... simple project became expensive project!
Bill
head gasket replacement tonym509 Supra Forum 7 01-24-2006 08:38 PM
Removing Gen2 camry head unit? crazy_camry Audio, Video, and Security - Tech 11 10-02-2005 11:04 PM
removing head unit jeep2tacoma 2nd Generation (2005+) 1 05-10-2005 10:40 PM
removing my head unit cam98hi Camry & Solara Lounge 1 02-25-2005 04:57 PM
Removing Head Unit of 04 Tacoma 1flycamry 1st Generation (1995.5–2004) 2 12-28-2004 11:47 AM
