electrical/lighting issues
ok, 86 corolla gts. got a few issues i would like to ask for some advice on.
1. my passenger side headlight is considerably dimmer than the driver side. the lights are different brands so i assume the drivers side has been replaced. is it just the light or am i looking at bad wires or amps or something going to it.
2. the lights dim slightly when i hit the brakes. also turning the lights on and such cause a slight drop in idle rpm's. seems the lights are putting on a heavy load on the system. it does have an old battery so is it just the battery or something else i should check on.
3. the most annoying. sometimes the lights don't want to pop up or turn on. running lights work perfectly fine. sometimes the headlights work fine, other times they will pop up and not come on, and sometimes they wojn't even come up. hitting on the panel seems to cause them to come up if they are down, but then they won't turn on. if they come up on their own hitting on the panel makes them come on after a while. anyone got a suggestion. do i need to clean out the switch, get a new one or what.
thanks for any help!
