Starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2006, 05:38 PM   #1 (permalink)
View Rollaluvr's Photo Gallery
Starting problem
ALright here is my problem, my 96 has been starting pretty good so far, but today I was gonna go for a drive, but for some odd reason, my car did not start it just made a ticking sound, it was a very rapid ticking, but after a few minutes it started right up, could this be a problem or what
James
Rollaluvr is offline   Reply With Quote
Old 01-23-2006, 05:46 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Might be starter/battery problem
Old 01-23-2006, 05:50 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Rapid ticking will most likely be a bad connection at the battery. Inspect the terminals thoroughly and clean/replace as needed.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-23-2006, 08:41 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
the other thing it could be is, the starter may have a shorted winding in it so when it tries to engage it shorts the battery then it losses power disengages then gets power again and this repeats very quickly hence the chatter. keep an eye on it if it keeps it up might need a new starter
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 01-24-2006, 07:01 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
As odd as that sounds it's a possability. In the 20years I've been building alternators and starters I've only seen that happen about 10 times. You are correct though, there's a tiny ground wire that on occasion breaks inside the solenoid and causes the exact same result.
雄のハヤブサ
Old 01-24-2006, 10:16 AM   #6 (permalink)
You asked for it...
View azcorolla's Photo Gallery
All of these answers are correct. It's either the battery or the starter, and most likely is the starter going bad. Check the battery and connections first. If they're ok and this continues, the starter will eventually leave you stranded. Murphy will require this to happen in the worst possible place/time.
azcorolla is offline   Reply With Quote
1996 T100 starting problem Solidworkingman T-100 17 10-25-2008 02:39 PM
XB starting problem silverxb06 Scion Forum 5 03-29-2006 06:21 PM
starting problem sub0 Camry & Solara Lounge 6 07-28-2004 01:38 PM
Starting Problem Puzzle! Rycam Camry & Solara Lounge 2 11-26-2003 06:16 PM
