Engine tune-up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2006, 02:38 PM   #1 (permalink)
View kbg4's Photo Gallery
Engine tune-up
Hi,
I have a 2002 corolla with 100K miles. I'm guessing it's time for an engine tune-up. What is actually replaced with an engine tune-up?
Thanks
kbg4 is offline   Reply With Quote
Old 01-24-2006, 03:25 PM   #2 (permalink)
20v 4dr AE92
View Corolla101's Photo Gallery
Spark Plugs, Spark plug wires, Distributor cap & rotor, Fuel filter, PCV valve, Crankcase filter, i also did thermostat but i dunno if that falls under engine tuneup
Corolla101 is offline   Reply With Quote
Old 01-24-2006, 07:43 PM   #3 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
PCV valve? Crankcase filter? Are those just extra things you did, or did you get a shop to do it? And is it really needed?
SR5_4WD is offline   Reply With Quote
Old 01-24-2006, 08:30 PM   #4 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Spark plugs--factory Iridium's
Spark plug wires --- No dist cap and rotors. Your car doesn't have them.
If you want to replace the fuel filter. Good luck. It's part of the fuel pump assembly in the tank. Personally...I'd leave it alone.
PCV
Air filter
I'd also clean the injectors and throttle body.
Nad1370 is offline   Reply With Quote
Old 01-24-2006, 09:28 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If you haven't done a transmission fluid flush or change, or coolant flush recently, you should do that now. Change the differential fluid also.
2007 Camry 2.4L 5M
Old 01-25-2006, 06:45 PM   #6 (permalink)
20v 4dr AE92
I did them myself, PCV is just for emissions and it really doesn't do anything...
Crankcase filter I dunno what it does
92 Previa Cold Engine Miss leanscribe Previa Forum 2 04-23-2005 04:26 PM
Personal Engine Tune up's Jagwire Camry & Solara Lounge 7 04-12-2005 01:04 AM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
Just got a tune up, now engine idling weird xaznxeclipsex MR2 Forum 5 05-27-2004 10:31 AM
Turbochargers Xenon Hardcore Tech and Competition 13 01-04-2004 08:12 PM
