jammed starter??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2006, 02:42 AM   #1 (permalink)
View littlewings's Photo Gallery
jammed starter???
dunno if this is a repost. lasnite when i start my car, the engine is on but you can hear a sound from the engine as if you're still turning on the car keys (engine is on). i shut the engine but still i can hear the sound from the starter (as if someone is turning on the keys) ..it stopped only when i disconnected the battery. if i reconnect the batt i happen again. what do u guys think? is it the starter? coz if it is i want to DIY...i'm using the smallport 4age..thanks
zzzz....
littlewings is offline   Reply With Quote
Old 01-26-2006, 10:53 AM   #2 (permalink)
You asked for it...
View azcorolla's Photo Gallery
Your solenoid is stuck. I don't know exactly how the Corolla starter is set up, but in some cars it is right on the starter, in others it can be mounted elsewhere. You may be able to unstick it by giving it a couple whacks with a hammer or other heavy object (careful not to break anything, of course). To find it, it will have a big wire coming from the starter and another going to the battery, and another small wire or two attached as well.
If you do get it unstuck, you probably should get it replaced as soon as you can.
azcorolla is offline   Reply With Quote
Old 01-26-2006, 06:28 PM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
its right on the starter, this condition where the starter won't shut off is dangerous it can cause a fire in the starter or wiring, get it looked at.
its caused by the contacts in the solinoid welding or melting together
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 01-26-2006, 06:56 PM   #4 (permalink)
yup..i take out the starter and have a look at it. i tried to connect it directly from the batt,all i can see is a non stop spin from inside the starter.will get a replace of the solenoid.
Another thing, while getting it unstuck i can see fire spark when it touches the engine itself (batt still connected) and it happens a few times. will it affect the whole wiring of the car coz i'm afraid after i fix the starter then comes another problem(ie wiring failure). sorry coz i'm still noob in car matters.
zzzz....
Old 01-27-2006, 10:29 AM   #5 (permalink)
You asked for it...
Where exactly do you see the fire? If it's where the starter casing touches the motor, and while you have it unbolted, it's probably just because the starter is not getting a real good ground and will not happen when you bolt it back in place.
1988 Celica starter problem usmc Celica Forum 7 09-13-2005 10:25 PM
Need Help With Starter Eye8Pussies General Discussion 9 05-24-2005 03:58 PM
Starter Problem clauser Camry & Solara Lounge 2 03-09-2005 06:50 AM
Starter noise while engine is running shogun6684 Archived Corolla threads 0 02-21-2005 01:17 PM
87 4Runner Starter Advice Needed DesertDave57 4Runner Lounge 10 08-17-2004 09:17 PM
