headunit help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2006, 01:48 AM   #1 (permalink)
View mytoyotacorolla's Photo Gallery
headunit help
Hi, I need help on how to open the stock headunit on my
2004 toyota corolla-S. Thank you so much
I needed to open the headunit so I can plug in the ipod interface.
I was trying to put up the picture of my stock head unit but I don't
know how. Please help, thanks
mytoyotacorolla is offline   Reply With Quote
Old 01-27-2006, 09:35 PM   #2 (permalink)
caddymac's Avatar
View caddymac's Photo Gallery
First off, why? Secondly, you can't host pictures from your computer hard drive.
caddymac is offline   Reply With Quote
Old 01-28-2006, 03:16 AM   #3 (permalink)
stock head unit
I want to plug in the ipod interface so I can use my ipod in the car. I don't know how to put up a picture of my stock head unit so people can help me to open it. Please help, thanks
Old 01-28-2006, 05:00 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
go here www.photobucket.com register, then upload your pics there and post the link to the pics on their site.
Old 01-30-2006, 02:07 AM   #5 (permalink)
headunit help
Here are the pics of my stock headunit that I need help to open it so I can plug in the ipod interface.
http://i37.photobucket.com/albums/e9...5/DSC01739.jpg
http://i37.photobucket.com/albums/e9...5/DSC01736.jpg
Old 01-31-2006, 01:53 AM   #6 (permalink)
KDM is in
REN69's Avatar
you mean you need to "take it out" not open it. I think someone here has done it already. give it a couple of days till they show up.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 02-01-2006, 06:29 AM   #7 (permalink)
caddymac's Avatar
Somebody correct me if I am wrong, but I don't think that model of radio has CD changer controls on it.
Old 02-01-2006, 07:40 AM   #8 (permalink)
View jlinn05XRS's Photo Gallery
I was wondering how you remove the head unit in an 05 corolla XRS it has the 6 disc changer built in.. I am hardwiring my sirius satellite radio in it thanks
jlinn05XRS is offline   Reply With Quote
Old 02-01-2006, 11:44 PM   #9 (permalink)
caddymac's Avatar
jlinn05XRS, do you have an adapter to use for input? If not, you will have to get one before attempting to hard wire your Sirius in.
To remove the radio, first remove the trim around the shifter. Then pull the middle HVAC knob out and remove the screw located underneath. Next the trim containing the clock and the remaining HVAC knobs needs to be pulled from the dash. Then grab the vents by the radio and pulll the entire trim piece out. At least that's the way I remember doing it.
I found it was a nice help to take the glove box out to help mount my Aux2Car box.
Old 02-02-2006, 01:52 PM   #10 (permalink)
headunit help
Hi, thanks for showing me steps to remove the stock headunit on my 04 toyota corolla. By any chance if you have some pictures of the steps to remove the stock headunit? if you do that would help me a lot. Thanks again
Old 03-24-2006, 06:54 PM   #11 (permalink)
View the4starish's Photo Gallery
I'm having the hardest time with removing the panels to get behind my headunit. I was able to remove the shifter trim with no problem and I removed the AC knob and unscrewed that with ease. But I cannot take off the other two panels necessary to remove the stereo (the vents, and the middle dash piece). Is there any trick to it? Do I need to use some tools? It just feels like I'm going to break things. I struggled with it for about an hour after giving up. The part I'm having the most trouble with is the middle dash panel piece (the one with the AC knobs and clock etc). Any help? BTW I have a 2006 with 6 Disc In-Dash that I'm trying to remove so I can install and Aux-input adapter on to it. I followed some tutorial that someone made on the internet, but its not as easy as it makes it seem. The panels are really tough to work with. Anyway, I'm just rambling now, any help would do. thank you.
the4starish is offline   Reply With Quote
Old 03-25-2006, 12:45 AM   #12 (permalink)
View arens's Photo Gallery
After I pulled the trim from the shifter I let it hang just in front of the drivers seat. I then turned the ignition key to the on position and shifted into low to get more room for the HVAC/clock panel. To get this panel off I started by pulling from the both bottom corners at the same time. It was kinda tight the first time. I had to pull it again to get the CD I left in the stock HU and it was much easier the second time around.
arens is offline   Reply With Quote
Old 03-25-2006, 03:38 PM   #13 (permalink)
Alright, after some work, I got off the HVAC panel. Now, I cant get the vents off, also, I cant find the right tool to remove the four screws/nuts that attatch the headunit to the car. I used a 10mm wrench attatched to a hand crank and could remove the two that are closest to me, but the two that are far back are hard to reach, how'd u guys do it?
Installing New Headunit in 1999 4Runner hari_trivedi 4Runner Lounge 0 05-02-2005 04:17 PM
ae92 sedan headunit removal? (pic included) awdark Archived Corolla threads 9 10-20-2004 12:26 AM
