Life span of shoes/drums - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2006, 10:54 AM   #1 (permalink)
View kbg4's Photo Gallery
Hi,
I have a 2002 corolla with 100K miles. I'm not sure if I need to replace my rear shoes and/or drums. Is there a typical replacement interval for these? I would visually inspect them but it doesn't seem as straightforward as pads/rotors. Thanks for your help.
kbg4 is offline   Reply With Quote
Old 01-29-2006, 12:23 PM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by kbg4
Hi,
Easiest thing to do if you can't/don't want to check it yourself is take it to a place like NTB for a free brake inspection...I would think at a 100K your getting close but if its not scraping yet you should at least need a brake adjustment and a E brake lube/check ...Good Luck....Radd Guy...
If you must choose between two evils, pick the one you've never tried before.
Raddman is offline   Reply With Quote
gen4 dome light albertcua 3rd & 4th Generation (1992–1996 & 1997–2001) 18 08-04-2009 01:03 AM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
Bulb part #'s????? redgtxdi Archived Corolla threads 3 09-16-2005 10:17 PM
Question Bulb Type for rear turn signal cman2000 Camry & Solara Lounge 3 03-24-2005 10:53 PM
Interior Lighting luisitol Camry & Solara Lounge 23 10-17-2004 03:18 PM
