Andrew. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2001, 11:37 AM   #1 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Yeah, the AE101 brakes are the same. It's kinda like the AE92 GTS and Sedan brakes. I think the guy from JRP has TRD(!) brakes on his. Not too sure if you need to swap the whole suspension over for the swap though.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 11-29-2001, 01:34 PM   #2 (permalink)
View bondobondo's Photo Gallery
i was on some austrailian rolla page and they say on the ae92 that the front calipers can be swapped with ae111 or ae101 with no problems or fabrications.. the ae101, ae111 are supposed to have larger diameter rotors....
thanks for the info!
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
bondobondo is offline   Reply With Quote
Old 11-30-2001, 06:08 PM   #3 (permalink)
4Aaron GE's Avatar
Hmmm.... what about the rears? Can we use yours?
Old 12-01-2001, 02:07 AM   #4 (permalink)
hmmmmmm, true yours are only drum right?
i am pretty sure it would make perfect sense to swap over ae92 rear struts as i am quite sure that they are probably even the same part numbers, if not i am wondering if we line the parts up, how much of a difference would there be??
hmm
thanks
andrew
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
Old 12-01-2001, 01:51 PM   #5 (permalink)
actually i was thinking it over and you are going to see if the suspension linkages are in the same areas, if so, bob's-yer-uncle..
if not well then i guess bob is out of luck...
but i am sure rear discs should fit, if not then maybe from an ae111 or something of that nature.
i am almost 100% tho it will work..
just remember to measure up the demensions first!!
thanks
andrew
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
Old 12-01-2001, 07:09 PM   #6 (permalink)
Banned
View goodcookiedrift's Photo Gallery
i talked to the guy from jrp and he used the complete 101suspension. he tried to tell me some sh!t of how he imported over the whole subframe and built it up from that...yeah right...
anyways, with that said,i'm quite sure that an ae92 suspension swap would work fine. i want to explore that option.
Nick
goodcookiedrift is offline   Reply With Quote
ATTN: DEREK, RANDY, ANDREW and other tofu lovers goodcookiedrift Archived Corolla threads 6 07-07-2002 10:39 AM
Andrew Racing Rims... hittman General Discussion 0 04-03-2002 06:28 PM
Andrew I found The guy with the 20v Xenon General Discussion 4 03-19-2002 02:09 AM
ANDREW LEE goodcookiedrift Archived Corolla threads 8 08-23-2001 11:07 AM
Andrew Lee SR5boy General Discussion 2 08-11-2001 12:43 PM
