Insufficient EGR Flow - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2006, 12:22 AM   #1 (permalink)
View AdamF's Photo Gallery
Been having some troubles with my wife's 96 Corolla with the 1.6 and auto trans. It started sputtering a bit, and then threw a check engine light and got worse. Turned out to be a misfire. Pulled the plugs which has white speckled spots on them, replaced them with some Densos, and it cleared the code and all seemed well. Now, at idle, every once and a while it will "miss", for a second, but only at idles. Runs and drives great. The other day the check engine light came on again, and it read insufficient EGR flow. So I'm going to try cleaning out the EGR valve and ports.
My question is, do you guys have any pointers on doing this job? Whats the best way to clean out the valve itself? Soak it? In what? Blast it with compressed air?
AdamF is offline   Reply With Quote
Old 02-02-2006, 11:27 PM   #2 (permalink)
Nobody? I'm going to do this tomorrow.
Old 02-03-2006, 06:05 PM   #3 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
EGR postion sensor I believe
BadChicken is offline   Reply With Quote
Old 02-03-2006, 08:46 PM   #4 (permalink)
Thanks.
I cleaned out the EGR today. It really wasnt even dirty. The check engine light came back on though. I guess I'll have to buy a vaccum pressure guage and test things out.
Thanks!
Old 02-23-2006, 01:15 PM   #5 (permalink)
View Aubrey_T's Photo Gallery
Check your PM Adam. Thanks!
Aubrey_T is offline   Reply With Quote
Old 07-09-2006, 09:39 PM   #6 (permalink)
View tpasigueno's Photo Gallery
bump for you. We are also having this problem with the egr insufficient flow code. does anyone know how to clean it? I'm still searching around for answers as well.
tpasigueno is offline   Reply With Quote
Old 07-09-2006, 10:09 PM   #7 (permalink)
wrench234's Avatar
View wrench234's Photo Gallery
have you tried cleaning the passage in the intake that the exhaust gas flows back into if that is plugged and not allowing enough egr flow through there is a vsv sensor basically a back pressure gauge that the ecm reads to determine egr flow it could also be bad to check the egr vavle itself you do need a vacuum pump to pull a vacuum and see if it holds,although insufficient egr flow does not normally cause a noticeable change in the way the engine is running it is basically an emissions item if egr flow was too much such as stuck open valve etc this would cause an internal vacuum leak and would be noticable make sure all vacuum lines to the egr control solenoid ,egr and,vsv sensor are all connected and there are no noticable cracks in them and also that none of these lines are clogged
nothing is fool-proof to a talented fool
wrench234 is offline   Reply With Quote
Old 07-10-2006, 12:59 AM   #8 (permalink)
Thanks wrench.
I went ahead and cleared the code and cleaned the intake filter.
If it comes back, I will check the ports the two hoses go into.
Btw, is there anything special I should be using to clean it with besides water?
Old 07-10-2006, 08:29 PM   #9 (permalink)
wrench234's Avatar
carb cleaner will work make sure it says oxygen sensor safe though
P0401 - EGR Flow Insufficient on 97 Corolla Adee Archived Corolla threads 0 11-12-2005 01:06 PM
EGR flow Insufficient bigG Camry & Solara Lounge 8 10-05-2005 09:52 AM
Insufficient EGR Flow waynek57 Camry & Solara Lounge 7 09-28-2005 09:55 AM
EGR flow Insufficient. Eyal 951 Archived Corolla threads 3 02-24-2005 02:28 PM
