Hard start after 6 day no use - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2006, 05:57 PM   #1 (permalink)
View koreywill's Photo Gallery
I jumped into my 2000 Corolla this a.m. to go to work after not having driven the car in 6 days. It cranked and cranked for about 45 seconds before it started. Everything seemed fine (light were bright, starter turned at the right speed, etc) but it just wouldn't catch. I'm thinking a slow leak in an injector allowing pressure to drop. Day after day uage and the car starts fine but this was a first. Thoughts?
Koreywill
koreywill is offline   Reply With Quote
Old 01-30-2006, 06:10 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
i got an intermittent problem with mine that sounds the same i think its just the fuel system leaking back to the tank slowly letting some air into the lines so when you go to start it theres a little air lock by the injectors that takes a sec to clear
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 02-01-2006, 01:18 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
AE92
My mother's 2005 Matrix XRS does the same thing, but it happens even after a day sitting. My 1990 Camry (currently at 345,000km) and my 1989 GT-S (230,000km) somehow do not! The jacka$$ I bought the Corolla from hadn't started it in NINE MONTHS when I went to see it, but it cranked-over after six rotations--on bad gas.
Does anyone know what the design difference would be between these model years? Whatever they changed for the newer models, it's causing this problem.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 02-01-2006, 05:13 PM   #4 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
98 + model Corolla's went to a returnless fuel system.
Either air got in the fuel lines and it took a while to get gas to the injectors like Rolla guy said or plugs were slightly fouled.
Nad1370 is offline   Reply With Quote
Old 02-02-2006, 02:16 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
after 6 days of standing still I wouldnt be surprised if air got in the fuellines.
Old 02-02-2006, 07:15 AM   #6 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
battery would be the first culprit.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 06-01-2006, 08:27 PM   #7 (permalink)
hard start corolla
As it turned out, you were right. I recently bought a new battery and after 6 days of sitting the car started right up. Good call.
koreywill
Old 06-01-2006, 11:49 PM   #8 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That doesn't mean the alternator is not at fault either though.. if the alternator is beginning to fail, the battery will not charge properly. Give it a few days, if the battery still holds charge then you're good to go.. if not then your alternator is failing.
Old 06-02-2006, 12:42 AM   #9 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
ALso make sure the terminals are clean and greased to stop corrosion
all the best....
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-02-2006, 03:17 PM   #10 (permalink)
FLCEGuy's Avatar
View FLCEGuy's Photo Gallery
My 2006 CE has a rather complicated fuel vapor recovery system. A note that came with the car says "It TESTS fuel pressure 5 hours AFTER turning off the ignition." A pump near the gas tank can be heard. I don't know if it is evacuating the fuel line or filler tube back to the tank or checking for vapor leaks or what? I know the gas cap seal on most cars since 2001 is a big deal.
My car is still like new (850 miles over 6 months) and sits for days between uses. It has never started without about three seconds of cranking, warm or cold, but doesn't lose a drop of fuel sitting in my garage. I'm averaging over 37 mpg in mostly suburban stop & go driving so I'm pretty sure it is working efficiently.
FLCEGuy is offline   Reply With Quote
RAV4 intermittent start failure scottdac RAV4 Forum 5 02-25-2008 02:22 PM
Car is Extremely Hard to Start in the Rain,Distributor Removal? 5spd V6 ClrTail Camry & Solara Lounge 8 09-10-2007 02:46 PM
My '93 Camry LE wont start... Anyone know why? philosophy251 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-29-2005 08:39 AM
01 Rough Idle, Stall, Hard Cold Start anr 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-30-2005 12:50 AM
