2002 spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2006, 06:44 PM   #1 (permalink)
View kbg4's Photo Gallery
2002 spark plugs
Hi,
Can someone tell me the brand and part number of the '02 OE spark plugs. I think they're NGK but I don't know the part number.
Thanks
kbg4 is offline   Reply With Quote
Old 02-03-2006, 11:32 PM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by kbg4
Hi,
Thanks
I think Denso makes Toyota plugs IK16 if its NGK here's its web for 02 toyota plugs...Hope this helps...Radd Guy
http://www.ngk.com/results_app.asp?AAIA=1388796
Raddman is offline   Reply With Quote
Old 02-04-2006, 04:25 PM   #3 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
The plugs in your 02 Corolla are Irridium, and good for 120,000 miles. NGK's are usually factory plugs, while Nippondenso's are replacements. I don't know the # off the top of my head, but if you call your local dealer, they will tell you.
mickeyd is offline   Reply With Quote
Old 02-04-2006, 05:05 PM   #4 (permalink)
Registered User
Raddman's Avatar
USA
Those Denso are Iridium plugs, the 120k is the optimum max of the plug but they suggest changing them well before then, I think I read between 80-100K, At about 80k I would just pull a couple plugs and if they look OK and your engine is running good leave them in and just keep checking them every 10K or so...Denso makes electrical parts for Toyota so I figured they might make the plugs too...Plus NKG make a wide range of Iridium plugs.....Radd Guy...
http://www.densoiridium.com/find_par...TOYOTA&action=
Old 02-04-2006, 06:53 PM   #5 (permalink)
mickeyd's Avatar
The denso #is SK16R11, the ngk#is IFR6A11. Your o/m will have this information.
Old 02-04-2006, 07:51 PM   #6 (permalink)
Registered User
Raddman's Avatar
USA
Then why does the NGK site list it for a 2002 corolla as IFR5T11.....You saying their wrong, someones wrong ....Radd Guy...
Copied from their site>>>>>>>>
Spark Plugs; 2002 Toyota Corolla L4-1.8L IZZFE Premium Plugs
NGK Iridium plug 4996 IFR5T11 0.044 DOHC (Original Equipment Manufacturer, and/or Original Equipment Service Part) $8.07
Old 02-04-2006, 11:48 PM   #7 (permalink)
The NGK website lists the IFR6A11 as obsolete so maybe IFR5T11 is correct.
Old 02-05-2006, 01:57 AM   #8 (permalink)
Registered User
Raddman's Avatar
USA
Don't say thanks.....Just pay it forword.....Radd Guy...
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
What kind of Spark plugs does a 2002 Camry LE use Streetglower 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-17-2005 09:28 AM
Iridium Spark Plugs!?!?!!? Matsu-Seo Yaris, Vitz and Echo Forum 6 12-03-2004 09:52 AM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
