Originally Posted by Tideland Prius
unless it's a push button type which would be harder to break into if it had a lock, I suppose, compared to the lift-up type (Corolla, Camry etc)
My Corolla has 4 small screws and 2 plastic tabs holding it in
I bet using a crow bar, jimmy bar, tire iron or a large screw driver I could break into any glove box in under 15 seconds no matter if it had a button lock, pad lock or was duck taped closed...Unless you could weld a steel safe somewhere to your frame
I would suggest leaving your valuables at home...A friend of mine just lost 25 credit cards, all his business checks and other valuables left in his glove box from his LOCKED business truck while he was in for 5 minutes getting a cup of coffee...Oh did I mention they stold his truck too?..So if they could break into an F150 and drive away in under 5 minutes what chance do you have with a locked glove box
...I will hit the junks yards once it gets warm and armed with only a tire iron(pointed end) see if I can break my record of 15 seconds
...lol what do you want to keep in that LOCKED glove box anyway...golf balls?...Radd Guy...
To the person that turned my signature New Year girl in as "Obscene"
