fuel injector resistance? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2006, 03:43 AM   #1 (permalink)
View kapone5684's Photo Gallery
USA fuel injector resistance?
I am looking for the spec on a 1989 toyota alltrac wagon 1.6 4afe injestor resistance. also looking for the spec of a 94 toyota corolla 1.8l 7afe feul injector resistance also.
hope to see your help
Rob
kapone5684 is offline   Reply With Quote
Old 02-07-2006, 06:05 AM   #2 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
I have the same car as you, but what is injector resistance? And is it in the manual, because I have one
SR5_4WD is offline   Reply With Quote
Old 02-07-2006, 11:14 PM   #3 (permalink)
USA
injector resistance is the resistance to current flow which in turn pulses the injector.
and yes it is manual and it is not stock at all.
Old 02-08-2006, 01:00 AM   #4 (permalink)
Gameroom cash: $134355
you sure it's an 89? all 89 4afe's were carb'd. The 90 (with greytop injectors) has a flowrating of like 170cc/min and is high ohm.
if you're looking for some higher flowing injectors that are high ohm, go with a smallport 4age (greentop injectors). They work on the stock 4afe ecu just fine, and are 250cc/min.
if you're looking for higher than that, you'll probably have to go to like a 4agze injector with a resistor pack.
Old 02-08-2006, 03:06 PM   #5 (permalink)
'96 Rolla DX
Actually my car is an '89 and it's EFI; it says so on the valve cover. And I believe my car has the green tops.
Old 02-08-2006, 03:40 PM   #6 (permalink)
unless they've been swapped... i doubt you have smallport 4age greentop injectors - the early 4afe's have 170cc/min injectors..... the greentops are 250cc/min..... that's a large difference.... the 4afe (unless modded quite well) would be running rediculously rich
Old 02-09-2006, 07:09 PM   #7 (permalink)
'96 Rolla DX
I can only tell you about whats sitting in my driveway right now. A 1989 Corolla Wagon SR5 4WD 5 speed. The injectors have green tops, and it runs fine. The only things I have done to it are a Ractive SRI a Cherry Bomb muffler, and Siverstar headlights. It has 181 000kms on the 4AFE 1.6L EFI 16V motor. What else can I say? I guess I could post pictures if you really need the proof
Old 02-09-2006, 08:36 PM   #8 (permalink)
View stubborn1's Photo Gallery
Not sure how much the reading change over the years, but I get 13 ohms when cold and 16 ohms after running the vehicle a while on my 98.
stubborn1 is offline   Reply With Quote
Old 02-10-2006, 01:02 AM   #9 (permalink)
I got a cold reading of 13.4-13.7 ohms of resistance.
thanks
Rob
Old 02-10-2006, 01:06 AM   #10 (permalink)
Is there any way you can take a couple of pics for me? I need a pic of the right hand kick panel without the kick panel cover the one by th clutch and aso a pic on the fuse block behind the passanger side kick panel aslo that would be greatly appricated.and I didnt mean to sound rude in my last reply to you but I built a custom engine it is no longe a 1.6 l it is a 1.8l 94 corolla engine in it. so i have some more diagnosing to do on what the real problem is with getting this car started.
thanks rob
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
New fuel pressure regulator design: Opinions Please synapse Hardcore Tech and Competition 11 08-29-2005 06:51 PM
Thoughts on Fuel Economy 200kT100 T-100 0 04-02-2005 12:24 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
