removing a 4A-FE from an AE92? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2006, 12:24 AM   #1 (permalink)
View aasaa_666's Photo Gallery
Hi, has anyone ever removed their 4A-FE engine from their AE92 with out an engine lift? or does anyone know a trick to it? I dont have a lift so I was wondering if I can still remove it from the bottom and then lift the car front end up and away from the engine, then maybe do it in reverse to install. I wanna know because I heard someone did something like that so maybe some one can give me some pointers on how to drop/remove the engine from the bottom without an engine lift. thanks.
aasaa_666 is offline   Reply With Quote
Old 02-13-2006, 01:02 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
i donno why youd wanna take it out from underneath? this is a MR2 thing
two things i will suggest, possibly try to rent a hoist at a rent-all probably get one for $40 bucks for the weekend
the other thing that i could suggest is to get a block and tackle (any good hardware store) and hook it around a 4X4 across a few rafters
my advise buy/rent a hoist! i bought one for $150 and i will never work without it totally invaluable tool
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 02-13-2006, 01:35 AM   #3 (permalink)
Gameroom cash: $134355
just make life easy & buy one..... you can find them for $150 new
Old 02-13-2006, 02:00 AM   #4 (permalink)
oh ok. could someone at least tell me the weight of this engine.
Old 02-13-2006, 02:52 PM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Yea thats the way I always do it, I've always it easier to drop out the whole subframe, just 3 bolts on the top of each strut, 2 engine mounts and 10-15 big bolts underneath.
Its a peice of cake really, all you need is a couple of mates to lift the car up and move it back afterward.
punter is offline   Reply With Quote
Old 02-13-2006, 03:32 PM   #6 (permalink)
the engine itself weighs around 200lbs or so... maybe 300lbs max. it's fairly light. the tranny is around 70lbs - i've been able to haul it around the garage with a broken collar bone (ie, with one arm).
Old 02-16-2006, 12:12 PM   #7 (permalink)
Koo'rolla Lives Forever
New'rolla's Avatar
View New'rolla's Photo Gallery
this is probly useless but i lifted mine out when i went to change the timing belt and the clutch... yep they went at the same time.. weird? anyways here's a pic of me underneath it.. haha
there are like 5 HIDDEN bolts on the back of the tranny.. it pissed me off
New'rolla is offline   Reply With Quote
Old 02-17-2006, 12:07 AM   #8 (permalink)
5 hidden bolts in the back of the tranny? um, no
the only ones that are difficult to find are the 2 bolts on the lower tranny mount... there is a plastic cover from the underside so the bolts aren't exposed & you can't see the mount from the top
Old 02-17-2006, 08:58 AM   #9 (permalink)
View barthmonster's Photo Gallery
Damn I wish someone had told me that!! Anyway if you do the engine-hoist thing, the tranny should come with it. On automatics, it has to actually, no room to separate them. I found all this stuff out recently during a string of obscenities...
The subframe thing from the bottom sounds nice actually. Another trick I learned the hard way and on this board: don't unwire the motor, instead disconnect the harness at the ECU (under dash somewhere) and poke the connecter thru the firewall to the motor and un-wire it later after separation. Wish I had done it this way...
barthmonster is offline   Reply With Quote
removing fusebox, AE92 mrdennmann Archived Corolla threads 6 03-25-2006 11:22 PM
Fs: Gta: 1990 Ae92 Gt-s sleepy Vehicles 35 12-09-2005 01:58 AM
4a fe head on 4age block fleetwood dicki Hardcore Tech and Competition 3 02-15-2005 12:03 PM
left over parts from canadagts for ae92 CanadaGTS Archived Corolla threads 0 11-06-2003 09:11 PM
