Will these 4age 20v 's go into a 84-85 ae96 shell? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2006, 03:35 PM   #1 (permalink)
View JoeJITSU's Photo Gallery
I just bought one and I have the single over head cam. I want to drop one of these (4age 20v)
JoeJITSU is offline   Reply With Quote
Old 02-14-2006, 04:11 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Whats then engine code of you current motor??
ae96?? never heard of that but i assume its just a 90 series corolla, if so that motor will bolt in and you should be able to use your current gearbox (if you need to).
Hard things
-Fueling (if your carberatored)
-Wiring (full loom and ECU would be best)
-auxileries (sp?) meaning alternator/PS pump etc.
Best to track down the 20v ones.
Heaps more little stuff, but i can't be bothered going through it.
More info would still be good.
-have you done anything like this before?
-Will you be doing it yourself?
-Whats your budget
-have you thought about brakes/suspension to deal with the extra power?
punter is offline   Reply With Quote
Old 02-14-2006, 04:54 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I think he meant AE86.. yes the 20V motors will work, but you will have to bang your firewall in to make room for the dizzy cap as it will stick out right into the firewall. You can also cut a hole in the firewall but not many people like to do it that way as it will screw up the rigidity of the body and frame.
Next time do a search on AE86 swaps dude.. this topic has been beaten more times than Tina Turner.
Old 02-14-2006, 07:14 PM   #4 (permalink)
Hard things
-Whats your budget
OOOOOOPs. Sorry...I mean AE86 shell.
Old 02-14-2006, 07:18 PM   #5 (permalink)
So how about the 16v red top. I just want a DOHC that will drop right in.
Old 02-14-2006, 08:04 PM   #6 (permalink)
The TN Member
Then you want a RWD blue top, (came out factory in the good ae86's) As this has the RWD water housing already. If you do that your probably going to want a T50 gearbox (your will last a while, depending on how you treat it) and the diff (smae deal as gearbox) from a 4age powered car.
There are heaps of guides on the net showing the different ways to deal with the problems.
More details would be good.
Old 02-14-2006, 09:26 PM   #7 (permalink)
thanks....Ill try to keep a lookout for one.
20v 4AGE HArness VladImpaler Archived Corolla threads 9 04-30-2006 08:43 PM
4AGE 16v vs 4AGE 20v blk head GeRm0MR2 MR2 Forum 1 01-27-2006 12:51 PM
20v 4AGE swap into AE86 Hachi Driven Archived Corolla threads 4 11-08-2005 08:05 PM
91 Corolla DX SW- 20V 4AGE??? OmegaZZ Archived Corolla threads 2 02-19-2005 08:42 PM
