95 corolla :I want to drain manual tranny fluid which is the fill and drain screws?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2006, 04:54 PM   #1 (permalink)
View 350TPI's Photo Gallery
I bought some 75w90 mobil one synthetic gear oil and want to drain out the old fluid.I am having a hard time shifting when cold and the original fluid has almost 300,000 miles!!! Anyway does anyone have a pic of which of these screws is the fill and drain plugs or can you give me a good descrption (size of bolt head etc).I did a search and didnt see anything.Thanks,chris.
350TPI is offline   Reply With Quote
Old 02-16-2006, 06:15 PM   #2 (permalink)
View Corrolla Boy's Photo Gallery
USA
well im not sure about toyota but the tranny i put in my mustang had to screw type things that u could put a socket directly on and take it off like a bolt
Corrolla Boy is offline   Reply With Quote
Old 02-16-2006, 08:16 PM   #3 (permalink)
Well i was hoping someone would know.I have checked both haynes and chiltons to no avail.There are alot of bolt heads under the tranny and i have no idea which are the right 2.ANYONE???
Old 02-18-2006, 12:27 PM   #4 (permalink)
One last time.Hopefully someone has done this!!!Help!!!
Old 02-18-2006, 01:02 PM   #5 (permalink)
USA
can u take som pictures of the tranny maybe that could help out
Old 02-18-2006, 01:30 PM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
On Toyotas, the drain plug for the transmission is usually a 10mm hex/allen key on the bottom. The fill plug is on the side somewhere and usually a 17mm bolt head.
2007 Camry 2.4L 5M
Old 02-18-2006, 02:05 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
maybe for automatics.
Corolla manual tranny has the drain bolt near the driveshaft, fillplug is on the front and its something like 24mm.
Old 02-18-2006, 07:34 PM   #8 (permalink)
View Maxpayne124's Photo Gallery
drains are usually on the side or the bottom, look for the biggest bolt or and out of place bolt; fills are usually on the front, again look for the biggest bolt, itll be above the drain
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
Old 02-19-2006, 09:03 AM   #9 (permalink)
Ok,well i think i know where the drain is then.There is a huge bolt head thats gotta be 20MM+.However the fill plug i am not so sure about.Nothing really stood out on the upper part of the tranny(where i assume it would be) or am i looking to high?
How to fill differential fluid && Solara strut bar on Camry touringcamry Camry & Solara Lounge 2 05-03-2005 03:56 AM
How to: Change tranny fluid? SmokeyWren 2nd Generation (2000-2004) 4 04-30-2005 12:51 AM
manual transaxle fluid aypstony Camry & Solara Lounge 2 05-18-2003 12:43 AM
