searched, cant find: 92 motor swap options - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2006, 07:51 PM   #1 (permalink)
noob Starlet owner
View usdm240's Photo Gallery
i just bought a 92 Corolla/Prizm with the 4A-FE. the problem is that it has 3 bent valves, which is cool because i got it for $50. however, i noticed there isnt much aftermarket support for the 4A-FE.
so, the question: what else fits in? i would assume the 3S-GTE would work with some minor mods and im sure the 4A-GE would drop in as well, but is there anything else thats works? im ready to get going on this project. any info would be mgreatly appreciated.
The Rides:
'93 Nissan 240SX 'vert
'81 Toyota Starlet
-Bruce-
usdm240 is offline   Reply With Quote
Old 02-16-2006, 07:52 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Search for AE92 swaps, 4AGE fits.. 3SGTE with MAJOR not minor mods.
Old 02-16-2006, 07:57 PM   #3 (permalink)
noob Starlet owner
when you say major, how major is that? ive done extensive swaps on Nissan's and i am a mechanic if that helps. wiring doesnt scare, so what would it take to get a 3S in a Corolla? and i will search that AE92 swap too. thanks heaps.
The Rides:
'81 Toyota Starlet
-Bruce-
Old 02-16-2006, 08:06 PM   #4 (permalink)
Gameroom cash: $147537
Cut and weld engine mount. Cut hood to fit top mount IC or custom make FMIC. You can't use your stock tranny. 3S-GTE usually come with AWD tranny which you can't use unless you do full AWD conversion. If you get the Mr-2 turbo tranny, you'll need 5S-FE tranny parts to make it work in FWD. So a 5S-FE tranny will be easiest to find and use but its not design for such high HP. Then you'll need half axle to connect the tranny to your wheel hub. Of course you can try to swap complete wheel assembly from a Camry or Celica. If you do that, you should swap the rear so you get rear disc also. So if you can get a Mr-2 turbo clip, you'll get most of the parts.
Old 02-16-2006, 08:35 PM   #5 (permalink)
noob Starlet owner
wow...wont be doing a 3S swap then. how about a 4A-GZE? any special parts needed, or is it just a bolt in and rewire job?
i guess the bottom line is this: i want more power. at least 200whp. i would prefer something turbo, but i guess i could handle something supercharged. im a complete n00b to Toyota FWD swaps, so dont flame me too hard.
The Rides:
'81 Toyota Starlet
-Bruce-
Old 02-18-2006, 05:09 PM   #6 (permalink)
noob Starlet owner
i guess maybe what i should have asked is what is the easier motor to drop in and use FI without having to do to much rebuilding/changing mounts, etc. any input greatly appreciated, especially links to How-To's.
The Rides:
'81 Toyota Starlet
-Bruce-
Old 02-18-2006, 06:52 PM   #7 (permalink)
KDM is in
REN69's Avatar
you could drop the 4AGZE in your car.. then take the supercharger out and replace it with a turbocharger. A lot of people do the 4AGZE to 4AGTE conversion as the motor is already strengthened for boost.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 02-18-2006, 08:36 PM   #8 (permalink)
View AVANT's Photo Gallery
Or just buy the GZ long block (why buy a supercharger when you're going to toss it), wrecking yard for the intake manifold and throttle body (GZ owners come with a 50mm TB while the easy to find NA comes with a 55mm) and other misc parts, then do a turbo. You'll need Megasquirt to fuel it properly (standalone). It'll get you your 200whp on a decent sized turbo and good tune.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 02-18-2006, 10:29 PM   #9 (permalink)
Gameroom cash: $121755
why would you want the gze intake manifold and throttle body??? they're crap! the intake manifold is like comparing it to a log style turbo exhaust manifold.....
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 02-20-2006, 08:36 PM   #10 (permalink)
noob Starlet owner
thanks for the info guys. is there a link to any right ups or How-To's on this, or am i own my own for this one?
The Rides:
'81 Toyota Starlet
-Bruce-
Old 02-23-2006, 02:24 PM   #11 (permalink)
View kilo_tech's Photo Gallery
you can try talking to the guys at www.phoenixtuning.com, they specialize in toyota swaps they can help you answer your q`s i believe.
kilo_tech is offline   Reply With Quote
Old 02-23-2006, 02:53 PM   #12 (permalink)
Exactly why I said a wrecking yard as N/A 4AGEs are easy to find. Looks I forgot to mention that part and only talked about the NA's better throttle body.
Log manifolds, imo, are fine for the typical turbo setup. Equal length manifolds are expensive and powergains are minimal (if any) on a car trying to only get 200whp from a 1.6L. Even the spool times will be extremely close.
Old 02-24-2006, 10:01 AM   #13 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Already been said... but yah, that's a lot of work!
Any swap is going to require wiring. It's good that it doesn't scare you, but even the seasoned swapper takes a solid week or 2 wiring, and that's after the research! It's no easy task.
Also, make sure to get an ECU, or you will have to go custom (Megasquirt or the like).
I second contacting Dr. Tweak at www.phoenixtuning.com, if anyone can answer questions it's him!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
89 MR2 SC - 314k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going!
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio
aaron7 is offline   Reply With Quote
Old 02-27-2006, 08:52 AM   #14 (permalink)
noob Starlet owner
thanks for all the pointers guys. i contacted phoenix tuning and im waiting on a response. im pretty sure im just going to go 4A-GE and turbo it with moderate boost and bolt ons. all i need now is some wiring diagrams.
The Rides:
'81 Toyota Starlet
-Bruce-
Old 02-27-2006, 10:58 PM   #15 (permalink)
or you could ask on here..... or search.... i've put up more than enough information to do swaps.... the "guys" ie one person from phoenixtuning (drtweak) is on this forum as well... just not all that often. Him and I talk tech stuff every now & then.....
can't find coil wire on '92 2.2 L jerseyfreeze 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-13-2004 12:45 PM
Where to find Intake for 92 MR2 N/A 92MR2 MR2 Forum 5 11-12-2003 04:55 PM
Where can i find TRD Indiglo Gauge for a 92 camry Gen 3 phat555 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-02-2001 02:36 AM
Where can I find Initial K Indiglo Gauges For my 92 camry §oUnd Killa 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-23-2001 04:59 AM
