4age cam selection - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2001, 08:30 PM   #1 (permalink)
Banned
View goodcookiedrift's Photo Gallery
Hey doods, maybe you can help me out. I'm wondering what the max lift i can go before I a) have valves floating or b) have to convert to an under bucket shim
club4ag says that 8mm is the max lift but i see some 288's, 304's and such with 7.8 and 7.5mm lifts. so does this mean that as long as i get stiffer valve springs i can run such a high duration cam?
mind you, i don't think i want to go so high for a semi street use, but i'm curious if i can.
Nick
goodcookiedrift is offline   Reply With Quote
Old 12-01-2001, 01:53 PM   #2 (permalink)
View bondobondo's Photo Gallery
say what?? you got carbs????
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
bondobondo is offline   Reply With Quote
Old 12-01-2001, 07:04 PM   #3 (permalink)
Banned
muhahahahahahahahahahahah!!!!!!!
Nick
Old 12-03-2001, 08:26 AM   #4 (permalink)
View neil85AE86's Photo Gallery
yes...as long as the lift is not too high, just add stiffer springs and away you go.
I've heard 8.3 is the limit, but some guys say you can go higher with no probs, if you want to get to the bottom of this, give Rich a call at tedcomponents.com, he knows valvetrains inside and out, and also sells some nice grinds made from new blanks (not regrinds) for a reasonable price ($400 US/pair), he'll also custom grind to your desired application.
I wouldn't go higher than 288 if your gonna run on the street at all.
Keep in mind that you should not get any more spring than necessary, since they add alot of resistance, and can reduce the revability and horsepower if you go overkill. Strong springs also cause drastically accelerated cam wear.
You may want to go with something like a 276 with a fresh set of stock springs, but that would probably limit you to ~7500 rpm before float.
Neil
Uber D.I.Y. Zenki Turbo
Squirted since '03
1994 Tercel 2dr 5spd
2003 Mazda MPV LX
neil85AE86 is offline   Reply With Quote
Old 12-03-2001, 10:15 AM   #5 (permalink)
Banned
so how do i determine if a spring is too stiff or too soft? are there spring rates per duration and lift of cam?
Neil, give me a holla someitme...i might get those checkman's off of you....depending on the ride height.
Nick
Old 12-03-2001, 06:27 PM   #6 (permalink)
3" drop I hear, Yasin runs them with his Illuminas and has had great results.
A bit much for me, kg/mm 2" drop would be nice.
Neil
Squirted since '03
2003 Mazda MPV LX
Old 12-03-2001, 06:32 PM   #7 (permalink)
Banned
how is it that everyone except me can run short springs on illuminas? is there a short stroke version of illuminas? because i don't see how.
hey, i don't mind a 3 inch drop...a bit much...2.25 would be okay.
3inch...might have to go with under axle exhaust no?
Nick
Old 12-03-2001, 08:01 PM   #8 (permalink)
DriftStar.com KingPin
View driiift_hachiroku's Photo Gallery
I know from seeing Yasin's and Mac's car (which both run those Checkman's) that their cars sit VERY low.
For some reason, Mac's car was lower than Yasin's car, but mac got some spring spacers built, so that wasn't a problem.
They both ran over-the-axle exhausts without any problems.
Maybe you should ask Mac himself as well as other Dori-kaze guys on their experience with those springs.
<font size=-1>[ This Message was edited by: driiift_hachiroku on 2001-12-03 21:01 ]</font>
driiift_hachiroku is offline   Reply With Quote
Old 12-03-2001, 08:12 PM   #9 (permalink)
Banned
some guy on club4ag selling trd japan racce springs...10k front and 8k rear...for 175! and we thought yers were stiff eh jover!!!???
i want a spring that will compliment the hts and the coils in the front well.
Nick
For Sale: TRD "Atlantic" adjustable cam gears 4AG GTSTWINCAM Archived Corolla threads 0 07-17-2002 03:00 AM
bought a 4age GoodSteer Archived Corolla threads 0 12-20-2001 11:10 AM
should i go for 4agze or rebuild 4age + turbo? Dacatz Archived Corolla threads 41 12-02-2001 10:48 PM
