Originally Posted by aasaa_666
I mean the other way around. I was told by a friend that a 4afe ecu would work on a 4age but I just need to know if it works the other way around too.
i answered your question how you asked it.
(to put it in simpler terms)
to use a 4age ecu on your 4afe..... your 4afe would need to be outfitted with the 4age electronics to run properly (otherwise the ecu won't run correctly). Which is:
a) going to be a lot of work if you don't know what you're doing
b) you'll need the exact correct 4age ecu (yes, it matters)
c) you'll lose power because your intake will have been restricted
