no-name brand intakes bought off of ebay are not made for a specific car. They are made for a specific diameter inlet,that is it. This is why people buy name brand intakes. Why didn't he just go to autozone and make one with their cheapo "kits" like all the other cheap hacks?
Anyways, there are a few hoses on the new Corollas. one leads to the smogpump. You know that hole behind the battery leading down by the wheelwell somewhere, that used to be connected to the snorkel running to the intake? That is the smog pump and I bet that right now it is sucking in unfilter air. This will cause a CEL. The Injen intake has a nipple for this hose, which needs to be attached because the ECU thinks that air is supposed to be removed from the intake supply to feed the smog pump. There is another hose coming off of the airbox, I forgot where it goes to, but it is important. Again the Injen intake has a nipple for this hose.
AEM, Injen, and K&N are the holy trinity of intakes. Stick with them and you should be fine. Just buy name brand and save yourself from problems guys.......
2005 Corolla XRS
Vibrant exaust, 30% tint, K&N Short Ram Intake, HKS grounding kit, ES motor mount inserts, TRD Springs, Koni Yellow shocks
