dies when cornering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2006, 02:18 PM   #1 (permalink)
View hotrod's Photo Gallery
dies when cornering
Have anyone else got the same problem as I have. My 93 corolla 1.6 wagon just dies when I turn to the left and accelerate. I have tryed with empty or full tank, but its the same problem.
I hope someone have solved this!
hotrod is offline   Reply With Quote
Old 02-21-2006, 02:41 PM   #2 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
power steering failure?
SR5_4WD is offline   Reply With Quote
Old 02-21-2006, 04:40 PM   #3 (permalink)
View l_touring_dude's Photo Gallery
Is this a fuel injected or carb engine?
2000 Toyota Corolla 4wd L Touring Wagon (AE104 with 4A-FE)
l_touring_dude is offline   Reply With Quote
Old 02-21-2006, 04:48 PM   #4 (permalink)
trigger's Avatar
View trigger's Photo Gallery
your battery lead May be loose
Also Aerokits. Paint jobs as low as $700
trigger is offline   Reply With Quote
Old 02-21-2006, 06:02 PM   #5 (permalink)
I Break Everything!
Froggmann's Avatar
View Froggmann's Photo Gallery
Had this problem a looong time ago, it ended up being the catalytic converter. It was plugged just enough to piss off the motor in turns but not enough to draw from the power of the motor. but it could be a bad PS rack as well.
1993 OJ Bronco 250,000 miles Back on the road, fun truck.
2002 Nissan Maxima, keeps me nice and spoiled.
2001 Highlander Limited, for the wife.
Froggmann is offline   Reply With Quote
Old 02-21-2006, 07:53 PM   #6 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
What do you mean by it dies?
Does the car just stall out? Or does it lose power but keep running? There could be a tear in your intake tubing that pulls open when the motor leans over under load, especially if it has a bad motor mount. (My 84 camry stalled everytime you came to a complete stop for a while becuase of that.)
Have you checked your oil? The oil could be sloshing to one side of the pan and starving the pick-up, especially if your oil is low.
-Chris
Chris Corolla S is offline   Reply With Quote
Old 02-21-2006, 08:34 PM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I remember hearing something like this on Dorikaze.com someone was having the same problem with their 4AGE on their AE86 and I think it turned out to be oil getting into the intake during turns. I believe this is what "Oil Catch Cans" are made for.
Old 02-22-2006, 10:44 AM   #8 (permalink)
Dies when cornering
It s injection engine, and its cuts off only when taking 90 degree left turn and accelerate at the same time. It cuts immediatly, like an electric cut, but no varning lights or drops in tachometer occurs.
If i Don``t accelerate its not occurs. Low or full tank is the same. Emission is alright, so i don`t think that the catalytic converter fails. Power steering is ok, I dosent feel any failure in it.
Old 02-22-2006, 11:38 AM   #9 (permalink)
'96 Rolla DX
Maybe something is loose like previous stated. Open the hood and see if stuff will move around or not. If you suspect something is loose, start the car and check to see if it's loose. If it's the problem, the car will stall or die whatever
Old 02-22-2006, 07:05 PM   #10 (permalink)
View igorien2k's Photo Gallery
a loose electric connection. check the battery cables
igorien2k is offline   Reply With Quote
Old 02-22-2006, 07:11 PM   #11 (permalink)
View AVANT's Photo Gallery
If not what they said, then it maybe your fueling. Weak Fuel Pump, Clogged Fuel Filter, etc to where you starve the engine in the turns?
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 02-24-2006, 09:16 AM   #12 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Mine does that... severe loss of power under sharp turning left. I have a carb though. I just learned to deal w/it!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 02-24-2006, 10:18 AM   #13 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
That would be my "guess" too...It has to be something with the fuel system.
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Car dies for no reason!!!!!! gearhead789 Supra Forum 19 05-18-2006 06:31 PM
Avalon dies after 10 mintue drive (Maybe it doesn't like my house) PEPMAN 1st Generation (1995-1999) 5 10-09-2005 09:37 PM
Car dies after shifiting into drive from park boost3dsupra Camry & Solara Lounge 6 05-06-2005 01:52 AM
99' Camry Start then dies Problem EBMCS03 Camry & Solara Lounge 6 08-30-2004 09:57 AM
