90 sr5 motor/HG questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2006, 09:33 PM   #1 (permalink)
View rollawreck's Photo Gallery
AE92 90 sr5 motor/HG questions
ok im prety sure my HG went on my corolla (#1 and #2 cyclinders have like 30-40 spi compression, others are fine). didnt drive it more than 2 mins after it happened, so it didnt heat up. coolant was down a little bit
ok my questions are:
1) is the motor a 4afe? ( its twin cam 16v)
2) ive been looknig around and found that it seems liek i have to take the cams out to get at teh head bolts, is there an easy way to so this?
how hard is it going to be to replace the HG on this car. teh body is great and the motor only has 180,xxx so it not too too many
any help/experisnces will be appreciated
thanks
rollawreck is offline   Reply With Quote
Old 02-22-2006, 10:23 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
4afe and the 4age are both dohc and 16 v....
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 02-22-2006, 10:37 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
the 4AFE is DOHC the 4AGE is TWIN CAM totally different setup. The twin cam setup is wider than DOHC setups.
Yes rollawreck, your motor is a 4AFE as its an SR5, I would price out what it will cost you to replace the HG and price out what a newer motor will cost, I bet you is very close.
Old 02-22-2006, 11:11 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
What the hell are you talking about??
DOHC = Double Over Head Cams
Its the same thing, no difference. They're both DOCH and both twin cam
punter is offline   Reply With Quote
Old 02-23-2006, 02:01 AM   #5 (permalink)
KDM is in
REN69's Avatar
oy! someone help me out here.. the difference is the way the cams are actuated I believe. Look at a 4AGE and then look at the 4AFE, sure they both got 2 CAMS but they're not driven by the motor the same way.
TWIN CAM is belt driven while DOHC is driven differently, I just can't remember off hand.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 02-23-2006, 02:54 AM   #6 (permalink)
The TN Member
No its just 2 different terms for the same thing, The way the cams are driven is irrelevent.
The cams are driven using belts in both motors. (Although in alot of F series one cam is gear driven off the other.
Old 02-23-2006, 04:33 PM   #7 (permalink)
twin cam is where there is 1 cam with the timing belt and not 2 like DOHC. the intake cam is driven off the exhaust cam with a gear under the valve cover. from everything i read, the motor in my 90 sr5 is a 4afe..
im doing all the work myself and i dont have a garage, so swapping the whole motor isnt an opton really. i got the head all disconnected and labled, i just have to take the cams out and head bolts now to get the head off now and replace the HG. so far so good, considering im used to working on hondas..
any help or suggestions along the way?
im pissed, got a brande new MVI 3 days before this...
Old 02-23-2006, 04:36 PM   #8 (permalink)
also found a great site that u guys might like too, this is where i found that its the 4afe and has lots of great info on ALL motors (4age, 4afe, 4af, and others)
http://aarc.epnet.com/application/8827/8827CH03.htm
ps- anybody in Nova Scotia, canada looking for an awsome shape sr5, hit me up, ill sell it cheap :P
Old 02-23-2006, 04:58 PM   #9 (permalink)
The TN Member
Have a read.
http://en.wikipedia.org/wiki/DOHC
http://en.wikipedia.org/wiki/Twin_cam
The are two terms for the same thing.
The way the cams are driven is not relevent.
Old 02-23-2006, 05:08 PM   #10 (permalink)
The TN Member
Also on topic, I've never looked under the cam cover of a 4afe but it is common on toyota motors to have to remove one camshaft to get at the head bolts.
Also bear in mind they normally have strange type of drive on the head bolts (can't recall the name of it at the moment) but its star shaped. A hex key can be used, but I wouldn't trust it to get the correct tourque settings when re-fitting the head.
Old 02-23-2006, 05:16 PM   #11 (permalink)
i dont think mine have that, i was looking today, even if they do, i think a 12 point will work. ill find out tomorrow
Old 02-23-2006, 05:37 PM   #12 (permalink)
damnit i was reading more and found that its a torx bolt for the head bolts, anybody know the size of the torx im going to need?
look towards the bottom here
http://aarc.epnet.com/application/88..._EMISSIONS.htm
Old 02-23-2006, 05:38 PM   #13 (permalink)
The TN Member
Thats the name, Was on the tip of my tounge
*edited after i read you last post.
Old 02-23-2006, 05:45 PM   #14 (permalink)
ya thanks, is there any way a normal socket would work for those? or am i going to have to go buy a socket JUST for head bolts...
Old 02-23-2006, 06:03 PM   #15 (permalink)
The TN Member
Sorry my bad its not a torx, got my self mixed up, the tool you need is a T-50
As seen here
http://forums.toyspeed.org.nz/viewto...highlight=torx
90 ST 4AFE replacement jap motor questions RyanGriffin Celica Forum 3 10-03-2005 07:37 PM
First Post - 90 SR5 power steering rack ?? rollawreck Celica Forum 9 09-26-2005 06:58 PM
sr5 questions Skylineracer59 Introduce Yourself Here 0 12-11-2003 10:50 AM
Questions on 90 Celica GT 90CelicaGT Celica Forum 8 06-22-2003 10:37 PM
