Originally Posted by barthmonster
A Sensor that is right under the Distributor (4AFE) and the electrical prongs face forward, sensor is orange. what is it?? I apparently lost the wire that goes to it when putting my new motor in... Anyone know where the wire that goes to this sensor ties to the harness??
if it's BROWN then it is the coolant temp sensor that leads to the ECU. The white one wire goes to your radiator switch, and the green goes to your cold start injectors (which is on the intake manifold) and your starter.....
Another sensor on the firewall, right side close to the fuel injection manifold. Sensor slides onto a small metal flanged piece that is bolted to firewall. Absolute Pressure?? I broke mine and it needs replaced.
MAP sensor.... will not run right w/o one
Wires going to Alternator... I have a round one that goes to the alternator, a bare one with a plain round terminal that goes to the alternator. A single wire remains that comes from this harness, where does it go?? A/C?? Alternator??
oil pressure sending unit.... kinda behind the alternator (on 4afe)
Which sensor of the above could give me a check-engine light. I have a new motor and the old one didn't give a check-engine light...
In the instance of an older 4afe..... i'm sure it's the lack of the map sensor.... although, mine did run on the 4age with ITB's with incorrect map readins and didn't throw a code. The coolant sensor not being connected would definately throw a code. Why don't you jumper the diagnostic plug (on the strut wall under the hood... and underside of the hood tells you what to jumper) and get the code?
