Is Sportivo a 2ZZ GE model in Australia?? Right?? Atleast I think it is. Don't believe in people taking wild guesses out of the thin air. I cannot speak for every Toyota motor since the stock factory air intake designs vary from engine to engine with some more restrictive than the others, but if you do have it then apart from sounding great yes you can gain between 9 - 13 hp at the wheels (around 10 - 14 HP at the crank) depending on your city altitude from sea level. It is because the stock airbox on most of the 2ZZ models is too restrictive especially at high rpms. Do not believe me?? Check out the dyno charts at
www.injen.com and check out Celica GTS or Matrix XRS (both of them have 2ZZ GE motors). You will see for yourself.
Personally speaking, I am getting Injen installed next month in April on my 2ZZ as well and my tech at the motorsports shop told me to expect around 8.5 - 9 whp and no more than that since I live close 3000 ft above sea level.
