The springs and struts off of an ae92 SR5 should fit your car.. You can get them off ebay. I'd try from a Tuner Shop though for part ordering.
As for motor stuff I can't think of any.
I was thinking of doing a custom turbo setup, small boost, maybe 6-8 psi...I already have a turbo, its a Cummins Diesel turbo that I got for free from a friend....and I can make custon plumbing and a custom exhaust manifold........
If your keen go for it, but have you thought about something to control the timing and fueling??
John
That Turbo is WAAAAYYYY to big. if its off a cummins 5.9 12v or 24v TD that came in a dodge ram. unless its off a cummins 4BT motor, then it MIGHT be small enough but i still think your motor wont spool it up yet alone getting a turbo management system
2008 Scion xB 5spd
AEM CAI - TRD Exhaust w/o Second cat -
-TRD 19's - Eibach Sportlines -
many other goodies
Actually the AWD wagons have different struts than GTS or SR5, the AWD wagons have cartridges, but they're different part numbers from the GTS cartridges.
My wagon isnt a 4WD version, but the turbo is from a 350, i suppose a detroit diesel, but i was also thinking of a 4AG(Z)E swap, but i have no clue as to where i can find a motor.
I'm running the ae92 sr5, and have gone through two suspension setups so far. Keep it simply and look into the ksport setup, then find a 4age of some sort to swap into the car. For parts, you can find most of them on ebay, or by searching around on various forums. You might even be able to find a few parts in the junkyard. I've started making a little store that revolves around ebay to help us out with our searches.
