Sorry its taken so long for me to get back to you.
It sounds like you have a wire crossed some where ... are you using the 87a relays? They're key, you cant do it with out them.
The rubber things are burning because you've got too much power going to the low beams (crossed wire) and the bulbs are heating up too much.
Other than this diagram there's not much else I can do to help...
http://www.toyotanation.com/forum/t67103.html
My suggestion is to remove everything and start over fresh. Use my diagram and a 93-97 corolla wiring schematic (I can scan the correct one for you if you need it or you can use a Haynes or Chilton Manual)
I had a lot of trouble like you're having when I first did mine but I didn't have the benefit of a nifty lil diagram like the one I drew up for TN. I prolly did mine over like five times till I realized most Toyota headlight switches have a constant positive and an alternating ground. lol.
As for the corners follow this diy,
http://www.toyotanation.com/forum/t76852.html
Good luck and let me know if theres anything else I can do.
btw if you can wait a month or two I might be parting out my rolla and I can clip the harness I made and post it F/S
