Need some help, might've botched a DIY mod. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2006, 04:20 PM   #1 (permalink)
View ScottSummers's Photo Gallery
Hi all,
I could use a little help, thanks. I tried doing that DIY mod on Vamp's page where you adjust the throttle cable. Anyways, I don't know what I did but it idles pretty rough when the engine is warm. Does anyone know what I can do to fix it? Thanks again.
ScottSummers is offline   Reply With Quote
Old 03-03-2006, 08:58 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Adjusting the throttle cable should be pretty simple. I did it on my car too. Did you make sure to leave a little slack on the cable? Also work the throttle with engine off and make sure it isn't sticking.
And finally, you don't happen to drive a 05+ Corolla with electronic throttle?
Buurin is online now   Reply With Quote
Old 03-03-2006, 10:51 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Did you maybe stress/tear/bump a vacuum line while working? Tightening/loosening the t-cable won't cause rough idle, just high idle if you tighten too much!
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-04-2006, 01:08 PM   #4 (permalink)
Nah this is a '01 corolla AT. So when you guys say slack you mean how much moved the nuts and pin right? Does it matter if I tugged on the cable? Thanks again guys
DIY Posts edphighlader04 1st Generation (2001–2007) 0 10-07-2005 08:35 AM
New DIY mod for the Camry CDub LXi Show & Share 16 07-18-2005 10:17 AM
cheap diy mod (56K...eh) adsaba1969 Show & Share 28 06-20-2005 10:17 PM
DIY - MORE LIGHT (9005 bulb mod) - Corolla FAQ addition BLUEMEANIE Archived Corolla threads 0 03-23-2005 11:26 AM
