Injector cleaner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2006, 10:14 PM   #1 (permalink)
View Governor's Photo Gallery
Injector cleaner
I am a noob on these cars so sorry for dumb questions...I cant put injector cleaner in my 89 Maxima so I was wondering if I can use it in these cars..
Governor is offline   Reply With Quote
Old 03-05-2006, 12:02 AM   #2 (permalink)
View Patman525's Photo Gallery
why can't you put injector cleaner in you maxima? is it carbed? if a car's got injectors i say put some cleaner in it. there are even cacrb/injector cleaners out there that work on both. it wont hurt a thing
LoW 'rOllA
Patman525 is offline   Reply With Quote
Old 03-05-2006, 12:13 AM   #3 (permalink)
View AVANT's Photo Gallery
I'm a fan of techron concentrate I put one in my cars every few thousand miles.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 03-06-2006, 02:10 AM   #4 (permalink)
Gameroom cash: $134355
if you actually believe to have problems with your injectors being clogged.... pull them out and take them to a place that does blueprinting & balancing.... costs like $50 for all 4 injectors.....
Old 03-06-2006, 08:42 AM   #5 (permalink)
View abimanyu's Photo Gallery
Or you can ask around your town if they have what is called AUTO RX, good stuff!!!!!!!!
abimanyu is offline   Reply With Quote
Old 03-06-2006, 09:05 PM   #6 (permalink)
Thanks guys...Injector cleaner not recommended in Maximas but I will put some in the Corolla..
Old 03-07-2006, 12:14 AM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
My dad puts injector cleaner on his 90 maxima, I don't recall him having any problems with it because of the cleaner. Although he does have the injector problem that this motor is well known for.
Old 03-07-2006, 01:47 PM   #8 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I'd recommend a good tank of premium once a month or something, rather than injector cleaner. Many mechanics will tell you it's unnecessary and can actually cause damage. I think I saw some posts last year where people mentioned the troubles thy had after using it.
I used it in my Talon around 1997 or so and it dropped my fuel mileage and throttle response (still don't know why). A guy I know used it in his AE86 a few years back and it started blowing smoke a day later. Maybe it dissolved the gunk that was on his seals, which were keeping compression good?!?!
Remember: the injectors are the single most reliable component on your car (especially on Toyotas), so be careful what you do for (or to) them. If it ain't broke, don't fix it...in other words, why do you think you need cleaner?
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-07-2006, 03:04 PM   #9 (permalink)
So don't change your timing belt if it doesn't snap? The "if it ain't broke, don't fix it" philosophy never stuck to me.
Part of good maintenance includes reducing carbon build up. A car with little carbon build up will run smoother and more efficient (in power and mpg) than a car with lots of carbon build up. Valves seal better, better air flow, reduces hot spots, etc.
Just as you gave out your talon as an example, i can tell you about my corolla. I was getting 30mpg with the car, then it blew a headgasket at 285k (this engine has never been rebuilt). When I took the head off, I had it pressure washed and cleaned up while I cleaned up the carbon on the pistons. Once I put everything back on, I started averaging 32mpg.
FYI, those additives that they put in premium fuels are injector cleaner compounds. That's why they all advertise "cleans your engine as you drive" now. However, it's in much smaller dosage than a bottle of concentrated cleaner. A bottle of good cleaner will work better than that premium tank of gas.
