well...
I passed by and saw this post and i decided to give my 2cents.. here i go..
MY girfriends celica st (92) has a 4afe ...the other day her car died.. and it was because of the stock igniter inside of the distr. She dint wanted to spend..220 in a distr. ... neither do i.. so i got a MSD BLASTER SS coil a MSD POWER TOWER (is supposed to be for chevy HEI distributor caps to convert them to External coil NOT for hondas but they work in whatever situation). After that.. i went to autozone (i work there) and bought a chevy HEI module ... in parts.. i spent around $65... now i am doind the wiring on it to make it run. I think if you know about ignition systems, and have time, is worth it.
The Chevy HEI module has a lifetime warranty.. and i mount it in an aluminum bracket near the driver side headlight so it get a lot of air.. Is easy to replace,cheap $15 and ast long. The msd ss coil.. "its suppose" to give up to 48kv ..i have it mount near the module... Again it's easy to replace and only $45.
The bad part of it is that you have to drill the stock cap and deal with the wiring, but once you get it to work it runs like the stock ign system.. or may be better. I would prefer a fresh distributor from toyota..but money wise i think is a good upgrade from the old stock distb.
Before you guys start complaining about what i said.. remember is my opinion , and try to treat me with respect. is not the first time that i do this .. i did it in my uncle's 98 mitsubishi diamante v6 3.5 and everything works perfect(tach etc), i did it because the ign coil inside the distributor died with just 105k miles.. and they dont sell just the coil. you have to buy the entire unit. Again it cost my uncle 75 dollars (around).. and the remanufactured distributor usually runs around $280.
At least it sounds good to me. About it's performance.. i prefer the msd ss blaster coil (or whatever blaster coil with around 48kv) versus the old stock coil. But again if you give me the choice between a BRAND NEW IN BOX.. toyota distributor... and a setup like the one i did,, i prefer the toyota unit.. i prefer the toyota if is from the dealer.. not a remanufactured.. or other part.
I hope it helps.. if you guys want the wiring when i am finished .. i will post what to do hopefully with pics.. i have to go to school tomorrow plus i work in the afternoon so i dont know exactly when i am going to finish.
Good luck..
