93-97 and 98-00 Sway Bar Endlinks the same? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 11:17 AM   #1 (permalink)
View SBUBandit's Photo Gallery
I've checked a few places and I seem to be getting conflicting reports on whether the sway bar endlinks are the same on a 93-97 rolla and a 98-00 rolla. I think they are. I need a new pair for the front, and I found a set of 93-97 rolla fronts for $35. Can anyone give me a hand with this so I can know whether to buy these endlinks. Some sites such as rockauto, show the same ACDelco part number for a 96 rolla and a 00 Chevy Prizm, but autozone says no. Any help would be greatly appreciated
SBUBandit is offline   Reply With Quote
Old 03-09-2006, 07:29 AM   #2 (permalink)
anybody?
Old 03-15-2006, 01:50 PM   #3 (permalink)
I take it nobody knows the answer to this one? Dang
Old 03-15-2006, 08:17 PM   #4 (permalink)
View SpyderGS's Photo Gallery
From what i've noticed when i had them up, they look about the same. I have an 01 and a 97 corolla, and can look either tomorrow or friday for ya.
SpyderGS is offline   Reply With Quote
Old 03-16-2006, 03:39 PM   #5 (permalink)
That would be great, because I found a new pair of 93-97 fronts, and I'd love to put them on my 00. Let me know, Thanks in advance
Old 04-26-2006, 02:24 AM   #6 (permalink)
View Cabanon's Photo Gallery
would to know if the reverse could be done
put a 98-00 sway bar on a 93-97.
i cant find any for my model, which is a 93 ae102
'93 AE102 LE 1.8 5spd
'77 TE31 Deluxe 2TC 3spd Auto
Cabanon is offline   Reply With Quote
Old 04-27-2006, 02:42 AM   #7 (permalink)
Default
View twopointfivebar's Photo Gallery
Canada
They are the same.
Part # for a 93-97:
http://replacement.car-stuff.com/par...howdc=true#top
Part # for a 97-01:
I just changed mine the other day, and here's a tip:
Your springs will expand when you jack up your car, so the sway-bar links will be stressed at both points which makes removel much much harder.
Start off leaving your car parked, and just turn the wheel completely so that you expose the link, remove the nuts and then the links. Make sure you clean out the allen key hole of any excess dirt, cause if there's dirt in there, and your allen key is not in completely, you can easily strip the bolt.
Install the new ones, and hand-tighten them, then you can jack up the car, remove the tire, and torque them properly to about 35ft-lbs.
twopointfivebar is offline   Reply With Quote
Old 04-27-2006, 12:37 PM   #8 (permalink)
is the Endlink upgrade something ?
what about this ?
http://www.hotchkistuning.com/cgi-bi...2002%20Corolla
would it fit ??
Old 04-28-2006, 12:14 PM   #9 (permalink)
Default
This looks like the entire swaybar kit without the links.
Those links in my reply are OE type that connects the bottom swaybar to the control arm.
'99 1ZZFE - E110
Old 04-28-2006, 08:37 PM   #10 (permalink)
so this thing should fit ?
Old 04-28-2006, 09:03 PM   #11 (permalink)
Default
fit a '93? not sure... but i know the endlinks are the same part #, that's all.
'99 1ZZFE - E110
Old 04-28-2006, 09:33 PM   #12 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
they should fit.... The fact that its an AE1xx gives it away. Alot of the stuff is the same, it is really just a facelift...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
'98 - '00 and '93 - '97 Corolla Tranny Codes Dr Tweak Archived Corolla threads 16 03-04-2007 04:05 PM
Camry - 97 V6 100,000 mi $6500 versus 98 V4 117000 mi $5700 jeelanik General Discussion 19 09-28-2006 06:21 AM
Will a 98 front bumper fit on a 97? 97corolla Archived Corolla threads 10 06-17-2005 10:29 AM
97 camry springs fit a 98?? TOYOTACOROLLA General Discussion 3 05-18-2005 01:29 PM
97 or 98 Camry Radio Install Help azn1028 Audio, Video, and Security - Tech 7 12-31-2004 03:10 PM
