Toyota auto dimming rear view mirror install? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 03:20 PM   #1 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
Before I order is a auto dim Toyota PT374-02030 dim rear view mirror hard to install on a '05?
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 03-08-2006, 07:00 PM   #2 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
Dunno, but I'd say save your $$$ .... flipping a lil lever is not all that hard - and works every time
PhantomS is offline   Reply With Quote
Old 03-08-2006, 07:58 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Hte hardest part is going to be getting fused power to it. There may be a wire in the headliner you can tap into if not you will need to run it down one of the a-pillars to get to ignition on power only.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-09-2006, 05:27 AM   #4 (permalink)
The stock mirror has map lights so there's juice there to tap off of but electric is there all the time.Got to tap an ignition post.
The problem on the Toyota part dimming mirror is that there's a note that the mirror cannot be used if vehicle has side airbags.
We have side airbags.
I talked to a guy from Brands Sport Automotive(where I've bought Toyota parts in the past) and he says the plugs might be different because of the side airbags.
I thought the problem would be running the temperature wire down the side panels would interfere with the airbags going off properly.
Don't need a temp reading on the mirror because it's by the odometer.
The guy says the Toyota mirror is made by Gentex Corp.
The Toyota mirror says Gentex Corp right on it.
I wound up buying a Gentex Corp mirror without temp and compass,just dimming and map lights for $90 with free shipping.
No Toyota plugs just straight wiring.
The Toyota dimming mirror with compass and temp reading is $240.
So $90 is a great price as I don't need the compass or temp reading.
Here's the mirror that's $10 less than I paid!
Then again shipping was free on my order.
http://www.autodimmingmirrors.com/st...oduct=50-GENK2
I found some directions for the install and it seems the wires still have to be runs down the side pillar.
http://www.rearviewautomirrors.com/D...stallation.pdf
The "cannot be used if vehicle has side airbags" on a Toyota parts site
has me a bit worried a bit.
Old 03-09-2006, 12:42 PM   #5 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Don't see why you'd pay so much money just to save yourself the flip of a little lever.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 03-09-2006, 04:08 PM   #6 (permalink)
How true!
I'm into gadgets.
However I may pass after I see what's up with the install.
Old 03-09-2006, 07:23 PM   #7 (permalink)
View karazy's Photo Gallery
[QUOTE=Joe B]The problem on the Toyota part dimming mirror is that there's a note that the mirror cannot be used if vehicle has side airbags.
We have side airbags.[QUOTE]
I have both on my 03 LE.
karazy is offline   Reply With Quote
Old 03-10-2006, 05:25 AM   #8 (permalink)
[QUOTE=karazy][QUOTE=Joe B]The problem on the Toyota part dimming mirror is that there's a note that the mirror cannot be used if vehicle has side airbags.
Toyota must have changed.
Here's a post I recieved from another Corolla site on side bags and the mirror option.
"I didn't see that you had side impact airbags. That is a problem. If you buy the leather package, you get the auto dimming mirror. However, if you purchase the leather package with either the moonroof, or the side airbags, you no longer get the self dimming mirror. This is because the roof wiring harness in cars with SAB or the moonroof is incompatible with the mirror. Thus you need to go somewhere else for the wiring. In cars like mine with a sunroof but no SAB, they run a wire underneath the interior winshield moulding to the fuse block. You can't do this on a car with SAB and so there is no way to get power to the mirror other than to splice off the dome light circuit, which would certainly blow the fuse. Unless that is, you have no moonroof, then you do have factory wiring to the mirror for maplamps (cars with monroofs don't have lamps on the mirror), and you should be able to tap into this wiring. This is the only way I see you being able to install this mirror"
Old 03-10-2006, 10:38 AM   #9 (permalink)
Maybe, because I have a moonroof and leather seats as well.
Old 03-10-2006, 11:28 AM   #10 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
I know you can't get the mirror if you ordered the Moonroof. Why? I have no idea...It is not like there isn't power up there. I like the auto-dimming mirror...but regular mirrors are better at night when you want to "see" who is behind you....like a Police Officer. It is harder to see what kind of car is behind you with an auto-dimming mirror.
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 03-10-2006, 04:40 PM   #11 (permalink)
You can turn the dimming off, with the touch of a button.
Old 03-11-2006, 11:41 AM   #12 (permalink)
caddymac's Avatar
View caddymac's Photo Gallery
My LE is the first car I've had in a long time that doesn't have autodim, and I really miss it.
I see there's a Gentex mirror with Homelink. Hmmmm...
caddymac is offline   Reply With Quote
Old 03-11-2006, 05:37 PM   #13 (permalink)
View Xrolla's Photo Gallery
I installed the Gentex mirror with homelink in my 04 almost 2yrs ago and love it. The range of the homelink is unbelievable. I ran the wires down the a-pillar and found ign switched wires under the dash.
Xrolla is offline   Reply With Quote
Old 03-11-2006, 10:25 PM   #14 (permalink)
caddymac's Avatar
Xrolla, does that mirror have a compass?
Old 03-11-2006, 11:07 PM   #15 (permalink)
Old Dood's Avatar
Yes, I know that. It is not instant though. With a regular mirror you can set the mirror at an angle that will cut off the headlights and you can still see the outline of the car behind you.
Toyota's Dyin out Valentino Celica Forum 16 07-23-2007 11:36 PM
Looking where to get some parts powder96ss 89-95 Toyota Pickup/Hilux 6 01-24-2006 08:45 PM
Looking For........... 1radtoy Pre-88 Toyota Pickup/Hilux 9 01-15-2006 10:27 AM
Discount on all TWM Toyota Short Shifters! TWM Performance General Discussion 0 05-19-2005 09:20 AM
For Sale: Toyota OEM electronic rear view mirror for 02-03 Camry NEW! denuder 5th & 6th Generation (2002-2006 & 2007-2011) 0 06-22-2003 09:23 AM
