4A-C and 4A-F head swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2006, 07:56 PM   #1 (permalink)
View semdj's Photo Gallery
Does anyone know if there is any major problems replacing the head on my 4A-C engine with the head fom a 4A-f engine. Everything I have found so far makes it look possible and easy, just have to modify my exhaust system as the exhaust manifolds are on different side of the head.
Thanks
semdj is offline   Reply With Quote
Old 03-14-2006, 12:19 AM   #2 (permalink)
Thanks
Doesn't appear like anyone has any info on this one???????????????
Old 03-14-2006, 01:35 AM   #3 (permalink)
The TN Member
View punter's Photo Gallery
It would bolt straight up. I've never done it, but problem areas could be things like the cam belt, and dizzy.
May well be a few other issuse, I wouldn't expect a big performance gain so I hope this isn't going to cost you much money.
punter is offline   Reply With Quote
Old 03-14-2006, 12:24 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I say try it!
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 03-14-2006, 07:25 PM   #5 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
What car is this going into? If the engine is mounted longitudinally, you might have some distributor issues
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 03-19-2006, 09:58 AM   #6 (permalink)
It is going into a transverse mount 1986 Corolla LX - plenty of room.
I don't beleive the timing belt would be an issue cause there is only one cam sprocket and the two cam shafts are driven by gears of the one sprocket.
The only thing I see is that the exhaust will have to be modified.
Preformance gain would be about 20 horse which is all the extra that I need
Any other suggestions from anyone would be appreciated.
Thanks
Old 03-19-2006, 01:37 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
oh thats right! I forgot the distributor on my 4af is on the back of the head not on the side.
Semdj you will have to cut a hole in your firewall to fit the head in.
Old 03-22-2006, 11:46 PM   #8 (permalink)
As I said my engine is a transverse mount (sideways) plenty of room on the side
No need to cut the firewall - you must have a longtitudinal mount - conventional front to back
Thanks
semdj
Old 03-22-2006, 11:52 PM   #9 (permalink)
4Aaron GE's Avatar
You know... To see the all the gains you're expecting from the 4A-F head, you may as well swap the entire engine in. I know it's a pain, but you're not going to get all 20 hp if you don't get the 4A-FE pistons in there. Of course, there's always the potential that the 4A-C pistons could result in higher compression and hp.
