1993 Corolla/Prizm Temp gauge stays cold all the time - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2006, 02:08 PM   #1 (permalink)
View dwikiz's Photo Gallery
93 Prizm 1.6L
The temp gauge never gets to warm. It will start being below the mark and then eventually it will get just to the lowest mark and then never go past. Does this indicate a bad thermostat? Im not sure because Ive always heard of the temp gauge reading really hot when that goes out.
Incidentally, Im also losing coolant somehow. The reservoir goes down about a half an inch everyday
Problems are probably related somehow but I figure the temp gauge oddity may lead to the solution to both problems
Thanks in advance!
dwikiz is offline   Reply With Quote
Old 03-10-2006, 05:34 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
id check the system for leaks, to track down the issue with it loosing coolant.
As for it never warming up it is most likely the thermostat try changing it and see where its at
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-10-2006, 07:35 PM   #3 (permalink)
View JohnO356's Photo Gallery
Is your heater blowing hot air? If so, it's your guage or sending unit. Also, how low is your coolant level? Refill it.
JohnO356 is offline   Reply With Quote
Old 03-11-2006, 08:57 AM   #4 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
If you top off the coolant and it still does the same thing, first place to look is the thermostat. Especially in a 93. Any troubles with the system before this?
adsaba1969 is offline   Reply With Quote
Old 03-12-2006, 12:49 PM   #5 (permalink)
View KaMLuNg's Photo Gallery
your t-stat may be stuck open...
'01 GS430
'07 Acura TL
'98 3.2 TL
'07 Rolla LE
KaMLuNg is offline   Reply With Quote
Temp Gauge always on Cold ? Broke ? GaviN Camry & Solara Lounge 9 01-18-2005 06:20 PM
Thermal time sensor and temp sensor went bad at same time toysarefun Camry & Solara Lounge 0 12-07-2004 12:56 PM
2003 Camry 4cyl - erratic 2000rpm revving with temp indicator light dropping to cold rmorgan210 5th & 6th Generation (2002-2006 & 2007-2011) 2 05-21-2004 10:12 AM
Update on progression on the Wraith!!!! 56K warning Wraith Hardcore Tech and Competition 72 05-08-2004 03:06 AM
