crack in filler neck, 95 rolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2006, 04:02 PM   #1 (permalink)
View wayfast's Photo Gallery
ok there is a little crack in the gas filler neck, and when you fill it up gas drips, i was wondering if i can use some JB weld to patch it up?
Thanks a lot,
Josh
wayfast is offline   Reply With Quote
Old 03-11-2006, 04:47 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
AE92
Only use JB Weld if you can grind the rust right down to metal all around the crack. Also, check to make sure (if you haven't already) that the crack isn't in the breather tube...
I'd recommend at least trying the patch solution, because replacing the neck is a gigantic PITA. The rubber hoses feeding from the tank get really brittle with age and if you're not careful, they'll bend/break the metal neck and/or breather when you try to pry them off.
Or you could go ghetto and duct tape a funnel to a garden hose and feed it past the crack when you fill-up! I did that when I first bought my Rolla, until I could replace it to safety the car. Not fun...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-11-2006, 05:18 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
It's probably rusted through thats why theres a crack. Get a replacement pipe, you dont want JB weld or other shit going inside the tank and clogging up the pump filter, especially on an EFI car.
Old 03-11-2006, 06:09 PM   #4 (permalink)
i found out it's actually a very tiny holee, but i cleaned it up and jb welded it
Engine Moisture In Oil Filler Neck Dufman 2nd Generation (2005+) 10 01-19-2012 03:27 PM
'95 Rolla with 14k miles. Possible problems with long highway trip? ASG14 General Discussion 32 01-10-2006 09:03 PM
Filler Neck - flapper piece roch00 Archived Corolla threads 3 08-11-2005 03:28 AM
My Nana's '95 Rolla...... ASG14 General Discussion 16 01-19-2005 04:09 PM
95 rolla door lining removal Sootie Archived Corolla threads 4 05-16-2004 07:56 PM
