blue smoke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2006, 08:42 PM   #1 (permalink)
View VaRolla91's Photo Gallery
AE92 blue smoke
Whats blue smoke from exhaust mean? i was racing my buddys oldschool celica with my AE-92 sedan,and i was infront,we were doing about 100mph..(interstate) and i was in front,(go rolla!!!!!!) and he told me when i let off the throttle he saw whisps of blue smoke ? i just did an oil change also,the care is in good care as well,good maintenence,im the second owner,my mother the first..whats this mean? is it gonna blow up or is this a thing that happens to older cars (its a 91) and could a good ol bottle of that stop smoke oil treatment stuff help? i've never used it on the corolla before but its never smoked before to my knowledge any input is Greatly appreciated as i love this car ALOT and if its got an issue it'll be fixed Pronto
VaRolla91 is offline   Reply With Quote
Old 03-13-2006, 09:49 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
some oil is burning for sure if it blue or black colored. Thgis will typically happen with older vehicles, but something is probably leaking. The stop oil stuff works ok, but not for along time. Basically the only way to fix that from getting worse is to rebuild... but thats not usually a good option for the expense part.
Corollacrazy42 is offline   Reply With Quote
Old 03-13-2006, 10:23 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
It means your car is burning oil.
My advice would be to not use stop smoke or any other oil additive, for the most part they do more harm than good.
Your problem doesn't actually sound that bad at all, Does it smoke on a cold morning when you start it?
Solution1 = just keep an eye on your oil level, and top up as required. (don't let it run out!)Solution2 = Try running a thicker oil, (keep extreeme climates in mind)
Solution3 = Rebuild/replace worn parts.
punter is offline   Reply With Quote
Old 03-13-2006, 11:01 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
You prolly need valve seals. Try this, find a long sweeping right turn that you can accellerate HARD all the way around, like an on ramp. At the end of the turn if you need valve seals you will probably be able to see the smoke in the mirror or stop suddenly and see if it's smoking. This works in a Tercel and they were designed by the same people so....
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-14-2006, 02:15 AM   #5 (permalink)
View 94_Rolla_Guy's Photo Gallery
i would agree with the valve seals. there not critical so don't worry as its a big job to change them, just keep the oil topped up!
If you do opt to replace them it is possible to replace them without removing the cylinder head, with the use of a air hold to keep the valves up and a bridge style valve compressor!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-14-2006, 07:13 AM   #6 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
valve seals or piston rings will eventually be mandatory. Keep racing and your compression will go down = no power = you losing
SR5_4WD is offline   Reply With Quote
Old 03-15-2006, 09:36 PM   #7 (permalink)
sounds like a plan, Rings,valves...sounds good,it shall be done,like i said,if theres problem with this car,it WILL be fixed ,thank you for input folks ......OR....i could just keep dogging it till it blows then i HAVE to get a new motor and hell why not just replace it with a 4A-GE???? eh...option 1 sounds better....no blowing motors...thanks guys
Old 03-15-2006, 11:49 PM   #8 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
Another valve seal test I had suggested to me by the guys at Torque Freaks:
Get going at a respectable speed on the highway. 70 or so.
Let your foot off the gas and let her coast down to about 60. (Creates a vaccum in the combustion chamber?)
Then apply the gas pedal liberally. If that kicks up some serious smoke, it's likely to be the seals.
I've been quoted $400, parts and labor, to replace them.
Piloter is offline   Reply With Quote
Old 03-16-2006, 12:09 PM   #9 (permalink)
View stubborn1's Photo Gallery
Typically, you will burn oil constantly with bad rings.
If it's valve related, you usually notice the effects more on a cold start or when winding out the rpms (puff of smoke between shifts).
My 98 has just started burning oil over the past few thousand miles. I'm burning a quart about every 1,500 miles. I figure it's cheaper to buy oil by the case and keep adding until something major goes wrong and then find a junkyard engine.
stubborn1 is offline   Reply With Quote
Old 03-16-2006, 04:26 PM   #10 (permalink)
The TN Member
Exactally, Don't fix it till it's actually broken.
Old 03-17-2006, 10:11 AM   #11 (permalink)
I Break Everything!
Froggmann's Avatar
View Froggmann's Photo Gallery
A slight wisp? If that is all or if you get a tiny bit of blue smoke on startup just don't worry about it. Likely a tiny bit of oil is getting by your valve guides. Until you start seeing that all of the time don't stress about it. It's more or less normal. When it does happen just get the head rebuilt and be done with it.
1993 OJ Bronco 250,000 miles Back on the road, fun truck.
2002 Nissan Maxima, keeps me nice and spoiled.
2001 Highlander Limited, for the wife.
Froggmann is offline   Reply With Quote
Old 03-17-2006, 03:36 PM   #12 (permalink)
AE92 Rock ON
Well,Rock On Guys,im at ease now,I LOVE that car,but since it only does it when im doing Over 100 & let off the throttle i think i'll be good for awhile,seeing as doing over 100 is NOT on this car regular daily agenda...and the OIl Level hasnt dropped at All since i changed it,which was like...the day before my FIrst question about it......So i think it's good to Go,just an Old car that doesnt like going over 100. Thanks again Guys....its Due for a Rebuild this summer anyways..found some internals for a 4A-FE that'll do it juuuust fine....
Old 03-17-2006, 03:59 PM   #13 (permalink)
I Break Everything!
Froggmann's Avatar
Yea don't do that anymore these cars are commuters not race cars. Sure they like to run away from you on the highway but don't press your luck. My Bro in law finally confessed on EXACTLY why the previous motor blew, he got the car to 110 held it there for a bit and once he slowed the car had a rod knock. I'm just now getting the motor back to where she was powerwise before the last motor blew.
Blue Smoke from the Rear CalgaryRav41999 General Discussion 5 10-19-2005 08:46 PM
blue smoke at morning startup howru Camry & Solara Lounge 23 08-04-2005 10:53 AM
blue oily smelling smoke brooker32 Tercel, Paseo, Starlet, and Sera Forum 2 06-08-2005 11:02 PM
Smoke from exhaust(not blue) stock93cam Camry & Solara Lounge 19 09-14-2004 10:16 PM
Blue Smoke from exhaust everytime famous182 Camry & Solara Lounge 30 09-02-2004 04:16 AM
