warm engine problems??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2006, 07:37 AM   #1 (permalink)
View eric496's Photo Gallery
Exclamation warm engine problems???
Hi, I have a 94 Corolla (1.8 L) with 178,000 miles and it has been super reliable up until now. This weekend I was coming home from Vermont and it started right up. I stopped at a store about 4 miles away and ten minutes later it would not start. We towed it to a mechanic and we were both having a hard time diagnosing the problem. After it cools off, it starts and runs well. We let it idle for about 10 minutes and took it for a test drive. It died after driving about 3-4 miles. It ran very rough and white steam/smoke was noted coming out of the exhaust before it completely died. I did a tune-up which was over due anyways and there is no change. Now it starts right up and runs good, but after a few minutes it develops a hesitation and gets worse as time passes. I'm a decent mechanic and I'm baffled! There are no trouble codes. My two thoughts now are a clogged cat or a weak fuel pump. does this sound familiar to anyone?? Thanks!!
eric496 is offline   Reply With Quote
Old 03-14-2006, 09:31 AM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Either one of those is a good guess. Worn out fuel pumps will stop working after they heat up, and a plugged up converter will cause and increasing lack of power the longer you drive. I would let it run with a fuel pressure gauge and an inline spark tester on it to see what cuts out first, then go from there. If neither one cuts out then look at the converter. Or have it towed to a better mechanic. Sounds like the mech you took it to dosent really know what to look for.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-14-2006, 12:08 PM   #3 (permalink)
Thanks! You're right about the mechanic. He was more of an equipment mechanic and tow buisness owner. He was trying to help get it running so we wouldn't have to tow it 100 miles to my house. He said it had spark, but I should check it as you said. It could be a coil. Right now I'm trying to locate a fuel pressure tester with a banjo bolt adaptor.
Old 03-14-2006, 01:54 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
run it up, let it die then check your spark sometimes i believe the pickup coil in the distributor can act up and die with heat that will cause the ECU to loose the rpm and cam position. but it could be fuel too so look at that too.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-14-2006, 05:59 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Most likely ignition module failure
Old 03-14-2006, 06:03 PM   #6 (permalink)
Gameroom cash: $147537
Yep, weak coil. Had that in my Celica. Start when its really cold, won't start when its hot.
Old 03-15-2006, 05:48 AM   #7 (permalink)
Plain ROLLA Mad
Psycho_rolla's Avatar
View Psycho_rolla's Photo Gallery
I had that with mine (Carby Version) I found it was my Battery
1989 AE92 Corolla CS 4A-FC 5 Speed manual
BIG SOUND in a little car
Psycho_rolla is offline   Reply With Quote
Old 03-15-2006, 10:17 AM   #8 (permalink)
Thanks for all the replies! I ran it last night until it was having problems and the spark looked ok. The battery is 100%. I had to mail order a 12mm banjo bolt adaptor so I can test the fuel pressure. If that's not it, then it sounds like I should pull the cat and have a look.
Old 03-15-2006, 05:37 PM   #9 (permalink)
View tashirosgt's Photo Gallery
Where did you order the bolt from? I'd like one for 89-93's.
tashirosgt is offline   Reply With Quote
Old 03-16-2006, 05:56 PM   #10 (permalink)
The adaptors are available seperately. http://www.actron.com/product_detail.php?pid=16173
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
2000 camry engine problems help? LONG jotka 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-24-2006 11:16 PM
2002 3.4L V6 Engine Problems masterstompy 1st Generation (1995.5–2004) 3 02-18-2006 07:41 PM
99 Camry Engine problems Phatslugga Camry & Solara Lounge 5 10-03-2005 11:49 PM
2.7L engine warm up thaibud 2nd Generation (2005+) 4 09-13-2005 05:58 PM
