Gas gauge not working properly?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2006, 01:37 PM   #1 (permalink)
Exhaust Time!
91_CorollaWagon's Avatar
View 91_CorollaWagon's Photo Gallery
Ok, the car has not run for 8 months, up until recently when I took posession of it and started driving it. I notice that the gas gauge takes a LONG time to come up to the correct position, and even after i fill up the tank, it NEVER goes to full (even though the pump clickes off.) It always just stops at little over 3 quarters, but the main point is that the gauge takes a long time to go back to its recent position from when the car is off. I cantgo back in the car and check the level because the gauge takes a long time to go up to the position. Is it because the car has not run in a long time, and the gague is a little sticky, and it will loosen up over time, or is the gague not working properly? keep in mind that the car has just a little over 32,000 miles. Thanks for your help!
John
91_CorollaWagon is offline   Reply With Quote
Old 03-14-2006, 03:31 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
mine takes a long time to go up after I fill up, and you can put another 2 or 3 dollars in after the click
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 03-14-2006, 03:50 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Yeah, the mileage on the car isn't so important--I wonder if the car sat with less than a full tank of gas, though. If there was any moisture in the tank, that caused your problem. The float-type device which registers the fuel level can "stick", thereby causing the guage to stop reading 'Full'. If any corrosion formed on the float arm, it's getting stuck at the 3/4 level even though the fuel is higher than that.
Given what a huge PITA it is to work on the sending unit/fuel pump assembly in the tank (on which the float is located), I'd just grin and bear it. As long as you know that the tank is full, and as long as the guage is reading correctly at lower levels, you're okay.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-14-2006, 04:29 PM   #4 (permalink)
Cressida nut
Gameroom cash: $213445
View kamesama980's Photo Gallery
most cars average gas tank readings average over the last few minutes, so they dont bob and weave with bumps in the road or acceleration. as for not filling up, my 86 camry and my 88 cressida both do (well the camry past-tense) that, if the pump handle is on the highest setting, it backs up right away. on the lowest it gets to about a gallon short of full. manually top off the last but as slow as i can manage and its fine. just watch that you dont overflow the tank. then it takes a mile or 2 driving before the gauge finally hits full.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'87 Chevy S10 pickup 4 cyl, M4, FOR SALE
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 03-14-2006, 05:36 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
I bet its the fuel reader... or whatever its called.. the floater thingy.
Old 03-14-2006, 06:47 PM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
The fuel sending units are about $40.00 new, from an online source, might look up the link later.. mine needs replaced to obut my wife says she can live without it working right..
eBay never seems to have the one for a 1989 Toyota Corolla SR5 !
retiredat44 is offline   Reply With Quote
Old 03-14-2006, 07:54 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
The floats get saturated with gasoline, they begin to weigh more and they dont float as well = fuel level never gets to full.
Old 03-14-2006, 09:08 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
and actually up and down hill my fuel gauge moves right away! there's no oh that was a few min ago...
Old 03-15-2006, 02:29 AM   #9 (permalink)
Exhaust Time!
yeah, it's still doing it...and the car was sitting with a half tank...ipp update next fill up.
John
03 Corolla S guzzling too much gas GaviN 9th Generation (2003-2008) 11 03-04-2008 09:13 PM
Theory.. Exhaust gas accelerator fan Punisher Archived Corolla threads 16 04-25-2006 09:33 PM
Aircon not working properly Khye Celica Forum 1 03-05-2004 01:32 PM
gas related email i got spydrvnm General Discussion 3 02-29-2004 09:11 PM
