Thanks so much!
Question:
The book talks about checking or measuring cam gear backlash with a dial indicator. I'm hoping I don't need to do this due to no apparent wear on either of the gears. If I DO need to do this, do I do it with that 'preload'-removing bolt installed or removed??
Did I do any damage by driving around with that noise for 5 or 6 miles?? It seems to only be 'noisy' when its warm, not really so much when cold...
I did have the cams out, I sort of 'rolled' one of the cams back into place, so sounds like this pre-load may be the problem. They come out easy enough I guess...
Anyone measure the valve clearance and set them yourself?? (shims??)
