mine did the same thing, if you're losing coolant from the reservior/overflow tank, then you should do what Ren said and fill the Radiator, i did the same mistake, and the car overheated and died on me on the highway, dont do the same mistake!!!
Mine was an external leak from the waterpump gasket, if you're not sure, take it to a shop and have them test it to see if it's internal or external leaking, they'll probably charge you $50-$70 dollars depending on some shops, make sure you ask them if they're gonna charge you. I took my car to a shop to see what was wrong with my brake bolts, they hoisted my car for 3 minutes, says that they'll have to call someone in to fix it if i want, but i said no, and charged me $70, im still kinda pissed off to this day, but some shops are like that, be careful and asked them what they're going to charge you just to look at your car, best wishes
